hello,
i was driving on the freeway just before and i looked down to check my speed and apparently i was doing 0 kmph.
Also the power steering failed at about the same time..
I pulled over and turned off the car... then turned back on and the speedo didnt work still but the power steering worked for about 80secs and then failed.
what could be the problem.. every time i turn the car on to drive the power steering only works for abot 80 sec then doesnt work. the HICAS light also comes on about 2 mins after the power steering fails..
could the power steering and speedo problem be connected?
i have an R32 GTR
thanks
Yes.. the problem is related..as power steering, and hicas relies on the speed sensor circuit.
Either your sender is stuffed, or the cable has snapped (check a diagram to see where the sender sits on the gearbox). Crawl under the car to take a look if you can see something obvious.
It's the speedo cable, it's either come un done at the gear box end or has chewed out the speedo drive at the top end. The speed sensor on the r32 is connected to the back of the speedo drive so when the cable goes, the hicas goes bonkers and power steering weight initially goes light, then the hicas light comes on and weight is increased over standard, but it doesn't stop working completely.
  • 6 years later...
TO revive an old topic, I also have this same problem my steering feels harder then normal and my speedo cable has snapped, Funny thing is my hicas light does not turn on and i know it works because in accesory mode the light turns on then turns off and when my fluid is down it also turns on. So my question is why isnt the hicas light turning on?
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
