SPLIT - CS Discussion from Sparkies & Oil Changes
I transferred from full time service to Army Reserve, so I still have access, work has been super keen to get me in to work in the OPS realm, so just turning up to use the gym......and ovens, isn't causing any issues, apart from me needing to keep on telling them that I won't be doing any reserve days until I get my joint in Goulburn sorted Basically I can now work whenever I want, for how long I want now, and it's all tax free Next time we have some fires or floods you might see me covered in mud, or cutting sick in some plant equipment cleaning up, the Reserves love getting in the news, LOL
Final finish outcome of 80°c was typical to the pics, I've turned the oven down to 50°c and will pick them up after the gym tomorrow The before and after difference was amazing, the wrinkle paint has covered all of the casting marks completely It did take a couple of hours to key it all and get in all of the crevices, but, for me it was time well spent for the final outcome, but I have all the time in the world to do it at the moment Ended up with 4 coats, each sprayed at different angles to get optimal coverage and thickness As for the fixtures and intake box thingo that hasn't made it, the supplier is apparently posting the fixtures, and, are now sending a different CAI that is in stock The replacement CAI is actually better than what I originally ordered, but will require a pod filter that locates under the front bar, still serviceable, but it basically removes the whole OEM filter box and ducts into the front bar, so filter cleaning will require ramps and the removal of some front bar undertray, not a war stopper, just some ramps and an additional 10 minutes work every few months From looking at it it is made from alloy pipe from the throttle body, through the CAI hole in the rad support, then right turning under the bar, luckily the wrinkle paint was on special and I got 2 cans for $30ish, so the alloy will get the same wrinkle treatment as the intake manifold, hopefully it turns up soon, either way, the car will be getting booked in soon, if the parts aren't here, I'll just get MX5 Mania to " make it work"
Exactly how each part works and how they all work together to make the engine function. That's all I'd need to do a basic build. Maybe how forced induction works. I probably need to learn some of the maths behind it all as well.
