rebuild rb26 800hp
exXU1
 Share
:kick: Looking for the following.USED ,in good "nick"
R34 gtr block or n1
Modified, decked, worked rb head( valves, springs)
2.7 ltr stroked bottom end or any components there in.
forged pistons rods etc
custom or G ready plenum.
straight cut gears for box
custom race / drag radiator
n1 oil pump
water injection unit
quality ECU
bosch or similar fuel pumps
surge tank
fuel rail upgrade
short shifter
I have a complete unit that may be what u need.........
RB26DET - 3.1litre, 500rwkw on pump fuel, totally reliable/streetable...plenum, cams, forged rods/pistons, 4wd sump, motec etc...been in GTR..
hope u have deep pockets tho....let me know if ur interested.
cheers,
Ben
R34 gtr block or n1
3.7 ltr stroked bottom end or any components there in.
n1 oil pump
motec ecu
surge tank
fuel rail upgrade
short shifter
R34 gtr block or n1
n1 oil pump
motec ecu
surge tank
fuel rail upgrade
short shifter
bosch 0580 254 984 pump 520hp-$300
Autronic SMC tuned to GTR complete-$1800
RB26dett cylinder head brand new,machined,new springs,ported etc.$3000
HKS dump pipes and front pipes all stainless-$1000
Thanks for your response, the head standard springs or upgraded to what type and make please.Interested in the ECU.Tunned for AFM or none on big single ?
Stockpilling info and responses ,
will make decisions in 2 weeks.
Thankyou
Dave
Thanks for your responses, nothing is going to waste,Keep it comming fellas,$$$$ spond'os waiting, just need more choices and to see what is actually out there.Money is a concideration but not a
major concern.
I just NEED what i want !
DEALERS , put in your 2 bobs worth. Any high hp RB 26 engines that you have imported?
RB26dett cylinder head brand new' date='machined,new springs,ported etc.$3000
Thankyou
Dave[/quote']
The are high perf..Iskenderian..hence the head machining.I have specs.No AFMs on Autronic,tuned for twins.
Dave.
  • 2 months later...
The are high perf..Iskenderian..hence the head machining.I have specs.No AFMs on Autronic' date='tuned for twins.
Dave.[/quote']
Time is now , please tell me more about the head please.Ported etc by a know rb head specialist or home job ?
What hp do you expect to produce with correct set up
Ta dave
Thankyou
Dave[/quote']
SMC tuned by who?
-Patrick
K seriously though, I have all the bits except the following:
R34 gtr block or n1 -- Mine is a fully prepped RB26 block from a R33GTR
2.7 ltr stroked bottom end or any components there in -- Mine is still 2.6L
custom or G ready plenum -- Didn't think it was required
straight cut gears for box -- Mine is a street car with an OS Giken cross mission set
water injection unit -- Didn't need it
short shifter -- Not required
Besides that, I have all of it including a fully tuned Autronic SMC with an Autronic CDI for that xtra spark ;)
R34 gtr block or n1
n1 oil pump
quality ECU
surge tank
fuel rail upgrade
short shifter
 Share
