Hey
Just bought some cusco camber tops suposedly from a 180sx. i've heard s13, 180 and a31 camber tops are all the same, well, these tops i bought are nothing like whats on the car. the cusco ones are not as deep ( so it would lower the car if i put them on) and the strut shaft is to small to fit in the bearing. any ideas? reckon i've been sold the wrong parts or have i got some funky suspension??
https://www.sau.com.au/forums/topic/67152-camber-tops/
A31/S12/S13/14/15 camber tops can be interchanged, provided you are running coilovers at the front.
seems to me he is trying to attach them to the stock style suspension. This can be done, but will require adapters and such to make it fit. You probably will find they will make the car sit a bit lower (as you have suggested)
https://www.sau.com.au/forums/topic/67152-camber-tops/#findComment-1248378
Yeah, i would not bother attaching them to stock suspension......with the sloppy feel of the standard items.....a bit of camber would make very little difference in the handling anyway.
Or is it for the "drift LOOK"?
Actually just lowering my car a little added way too much camber and it bump steers all over the shop. Maybe I should do the old key hole the strut top trick...
https://www.sau.com.au/forums/topic/67152-camber-tops/#findComment-1250826
