hey y'all
Well i can finally get my car from the compliance workshop but it hasn't been driven for about 6 months. Got a new battery, cat, brake pads, tyres, etc... but what should i do before i head out back down to Melb? I'm flying up to Sydney tomorrow in the morning, and going to the workshop so are there some things i should be checking?
Tyre pressures, oil, coolant, air conditioning, etc? Should i maybe drive it around the workshop area for 10-15mins, bring it back in, have a look and then head back out? It's a R34 GT-T, so i what should i be checking for with the 3 guages?
Yeah, just any advice about doing a long trip after a car has been sitting around for a while would be great!
cheers,
chinny
