Ok, I lied about the prize but you'll have my admiration for your knowledge...
I'm wondering what the little beige coloured box slung underneath the big gray box is. It's on the right side of the boot. The big gray one would be the HICAS controller I think? So the little beige one would be...(fill in blank:))
Hoping it's A-LSD...I've never seen a "slip" light go on but I don't nail the car that hard around turns and only had it for two weeks. There are 15 lights in the dash and never seen any of them come on except the ones at startup etc. (so handbrake, HICAS, ABS, oil, overdrive, airbag, engine - don't think I've seen any others)
Is there a part number on it?
/edit: it could be ABS controller - my brother's 32 has ABS and HICAS and it's two boxes. I don't have ABS on my 33 and I just have the HICAS box.
Q2: Do you have Active-LSD? It consists of two lights right in the middle of the tacho; "A-LSD" and "SLIP."
Hmm no there's no lights in the tacho itself :D But it's an auto so the tacho is prolly different? There's two groupings of 5 lights each on either side of the dials, plus various other lights scattered around but most of the lights have never come on and when they're not on they're completely black I can't see what they are.
Well what made me wonder is in another post someone suggested that in the model code for R33 if the 18th letter (factory options) is 'C' (which mine is) that means it has ALSD and ABS. I haven't seen this confirmed anywhere else though or anywhere to decode it...it definitely has ABS anyway.
The TOMEI HICAS locks are much smaller that that, and they are usually a small black plastic box, not metal. And I dare say that if it was a HKS one it'd be stamped with HKS all over it - you know how they love to stamp their stuff..
Have a look at the mounting brackets on the box, looks very factory to me.
J
EDIT: Just put the car into HICAS diagnostic mode and the HICAS works fine...rear wheels were doing their little turns etc
Hmm I dunno what HICAS feels like or if it's engaging...I do get a HICAS light when I start the car tho, would I still get that if the HICAS was disengaged?
I just have to know....it's eating me up.
What intrigues me most is it appears some skylines have "mystery-boxes" and some don't - factory option? Or have some original/previous owners removed their mystery-boxes for some reason??
Someone's gotta know...it's probably something incredibly mundane
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
