I have a mystery box in my boot too but this one is in the tail light loom with a switch on it and when i switch it the blinkers transfer to the stop lights!?!? why would anyone want this to happen??
It was put in there by the previous Japanese owner to mess with you.
Well, dunno if it was nissan or the previous owner but it sure is messing with me...
You know what would be cool? If before these cars went to auction the sellers had to fill out a (very short) form. Stuff like how many previous owners, what factory options it came with, any modifications etc....and the goddamn service manuals (even in japanese!!)
I wonder if S2s only have this? If so, then what do S2s have that S1s don't...apart from tasteful decor (sorry, just kidding)
R33 GTS25 series 1 type S (gawd, what a mouthful....) here (has HICAS), have both those boxes under the parcel shelf. Been meaning to get round to working out what the lower box is, if I remember I'll look it up in FAST, that should tell me what it is.
Ok, finally, a definitive answer.
Top (larger) box has part number 28505-16U15 on it, FAST lists this as 'CONTROL ASSY - HICAS'
Bottom (smaller) box has part number 47850-15U00 on it, FAST lists this as 'MODULE ASSY - ANTI-SKID'
So top one is HICAS controller, lower one is ABS controller. Note that on the boxes in your car the 2nd section of the part number may be different, I think that section of the number is the revision of the part.
Now where's that prize...... :cheers:
Excellent so it's ABS :P Thanks heaps for that Ant.
Unfortunately the competition was open to Australian residents only and I see that you are a resident of Kiwiville :rofl:
aww C'mon silver, giv da Kiwi a prize! :wassup:
Woohoo mystery solved, now I can finally get sum sleep at nite
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
