A Playstation Inside...
Baz
 Share
Hey,
I'm at the moment trying to decide the best way about installing my old playstation 2 in my car. Because I'm not the most brainiest when it comes to in car audio and installations I thought I would see what opinons I could get.
Basically I have already sorted out the power pack issue and have enough wire to run the red, yellow and white playstation inputs. What would be the best sort of screen I could buy to use? Does it need a deck to sit in? And would it have the red, yellow and white inputs? Also would it be easy to hook it up to the incar speakers with the ability to switch back to the original deck to play the radio and CD's when I feel like it?
All comments would be greatly appreciated.
Cheers
alot of newer decks have RCA inputs.. you can use them with the output of the PS2, so when you play that, set the deck to input or whatever.. then normal for radio/cd's :)
yup, alot of headunits on the market now have AUXILARY input...
just plug the audio from PS2 into the headunit, and the video cable into the monitor/tv.
if u have the old PS2 the best way is to mount it in the footwell of the passenger seat,
or you can do a custom install into the dash infront of the passenger - alternatively
you can buy the new PS2 which apparently fits perfectly into the glovebox.
 Share
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
    • If you really want squish back, you can have it put on the piston (at least to some extent).
    • Impressive. He's very very smooth.
    • What does IPDM stand for ?
