i bought a skyline and its lagging a lot and mechanic said its the computer, so im tryin to find out if i have the turbo computer or non turbo computer, so if anyone has info or the numbers for the n/a and turbo computer it will help a lot, the numbers on my computer are 2371004u70, mec - r117 / a1/ ox26, mec - r117/ a1 / 01814, thats all the numbers written on my computer
