Just a quick one..
Thing the headgasket may possibly be gone in one of my cars. Doesn't seem to be oil, but lot of bubbles. I know one of the coolant lines is split - could this be introducing air into the radiator??
If I need to, can I replace the headgasket without removing the whole engine?
I am thinking I can just remove the head, replace the gasket, then bolt the head back in, whilst the block stays in the engine bay. Is this achieveable?
How much is a replacement nissan genuine (or close to it) RB20DET gasket these days?
Thanks.
Head gasket can be done with block still in the car no worries. Its a bitch of a job, not that its hugely difficult but it can quickly snowball when you find you have to replace things(which is a good thing really) worst part of it all is getting the exhaust manifold off without snapping bolts. good chance to do timing belt while your there
good luck, tim
I was thinking just taking off turbo and leaving the ex manifold on too to make that easier :)
Intake manifold will be fun however.
I am not too sure at this stage, as I just stuck the compression meter in a couple of cylinders and it's not massively down. Should I check all cylinders?
vrs kit for rb25det(should be similar) is $250 from nissan and yes u can do it as said before with the engine still in.
you might find a few exhaust man studs broken as well as cracks in the manifold, have a good look.
look around where the head meets the block for coolant leaks, does your coolant level drop a lot quickly?
All cylinders were around 130psi give or take 5%.. my gauge always reads about 130psi on previous engines that have been in good condition.
So will that mean it is not the head gasket? I drained a fair bit of water whilst removing the hose.. no sign of oil in there. It just foams up the top which almost looks a bit browny (although that could be a bit of rust)
I did mix coolants the other day (i know you're not *meant to*) - because the hose was leaking I just had to top it up with some other coolant lying around go get by.. could there be a chemical reaction going on between the different coolants?
There hasn't been any signs of abnormal heat in the engine or anything like that recently.
As you can see I'm almost half way there (replacing a bad water hose) underneath plenum. So if is head gasket, maybe will just leave it apart and do the whole lot.
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
