if my standard timing on the crank angle sensor is at 20degrees advance and the values in the timing map in the power fc max 45 degrees what is the total timing,? is the 20degrees advance at the crank add to the 45 degrees in the power fc to give you the actual max timing.
https://www.sau.com.au/forums/topic/67233-power-fc-ignition-timing/
yes your std timing is 20deg at idle i think around 950rpm and when you set it make sure the pfc is reading 20 deg as it should do at idle , then the map read will directly represent the actual timing 20deg = 20deg ,45deg = 45deg etc
does this answer your question
pete
if i want to run 1.3 bar booste, what timing should i run, should i retard timing from the cas  , and then advance it from the power fc
Personally I always set the base timing at 20 degrees using the CAS, then adjust the ignition maps accordingly. If you want to test a straight line change (at all load points) then you can do it with the master ignition timing. Noting that it will revert back when you turn the ignition off.:)
