hay got a boost gauge and serched all the threads on it and they only show r32 and i want to know with pics if pos just one photo of where to cut the t piece in to any info would be great.
https://www.sau.com.au/forums/topic/67236-some-one-form-vic-please-help/
Should be same place as the 32 - into the hose between the plenum and the fuel pressure reg at the front of the engine.
In my opinion the best place to T-piece the hose is from the factory boost gauge hose.
There is a hose at the rear of the plenum going to a rectangle box, mounted on the driver’s side near the firewall. This box is actually the electronic circuitry that converts boost pressure to an electronic signal that goes to your factory electronic boost gauge.
I feel this is the best place as this hose is not connected to a critical item. Also is possibly the shortest length into the cabin.
As i do not have my car at home, this is the best i could do to show you which line i would use.
