Hi guys,
I know it's not a Skyline, but I know a fair few of you are fans of Chasers, so I thought I'd post up some pics of mine. It's still in Japan atm, but it should be here soon (hopefully).
It's a 99 model, series 2 JZX100 Tourer V.
The engine puts out 206kW @ 6200rpm and 378Nm @ 2400rpm
Series 2 taillights here - they look way better than the S1s imo.
Photoshopped to have a clear blinker (I'll be ordering these pretty much straight away)
I've got more pics (interior etc), but I won't post them unless people want them.
Cheers,
Michael
  • Replies 122
Yeah I quite like it too :(
I'd love some deep dish wheels for it, but after buying that I don't think I'll have too much cash left.
I won't be touching the ride height though - my last car had a 400R kit and that was so impractical. This is my "I've turned 25 and need something practical, but don't want to give up the turbo" car :)
It's not that bad a job is it? :cheers: That's my photoshopped one. Read just above the pic.
I was just trying to see how it would look without the hideous orange blinkers. I think the clear ones are on the Avante models, so I'll have to get a set of those somehow.
MIC33R, Oh my bad...
Question...is it a TRD version? From the badge upfront. Interior looks normal and the TRD version rear wing is?
None the less, nice buy. I was going to buy a Chaser but ended up pouring too much money in mods. Well also I found out Chaser could be imported so I didn't specially have to buy one to send home.
I also used to only like the series 2 lights but after a while the series 1 lights grow on you...they are both good IMO.
Nah it's just a plain version. I'm really not a fan of the TRD wing or front bar to be honest. I'd say the owner just bought a TRD grille (which is different to the TRD model's grille anyway). I actually prefer the meshed stock one anyway, so I'll be looking to swap with someone here unless they put the original one in the boot.
I still like the series 1 lights, but I prefer the S2 ones by far.
What sort of car do you think you'll bring back when you do come home?
Nice man.  I have to say I was seriously considering one of these but ended importing my R instead.   Very nice, might still end up with one of these in the future.....
A GTR was my other option, but I took the 4 door way. Maybe I'll regret it when I get the car, but I think I made the right decision.
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
