only fairfield police has them.. for driver education purposes, they were at drag combat last year spreading their message it was a STI though 2003
old news the thing still driving around crusing up T ways ect.....
fairfield police has them.. for driver education purposes :uh-huh: ;)
NXTIME, the one i've seen had the same decals... though its not the same car (it had the AA11AA number plate...)
I'm sure I saw the same car ur talking about on Fullers road the other day..
but didn't see the plate.. will keep an eye out next time
That Rex does indeed belong to the Fairfield police, they use it to promote racing in a controlled environment at WSID.
If anyone actually remembers, this is not the first time the coppers have used a Rex, back in 1998 - 99, the cops from central (Sydney) had a couple of the rare 2-door MY-99 STI's. I remember there was a big story about the coppers wanted to use them for ages but they couldn't until the automatic was available - Coppers are not allowed to drive a manual vehicle.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
