Hey, i have the following for sale, located on the gold coast .
Rb26 camshafts, good condition - $220
r32 gtst Dash Cluster, grey one - $80
M's K&N filter, with attachment for rb20/25 afm's(and matchin ones to them) $50
Genuine Nissan dot 4 Brake Fluid, (500ml bottles) $8 a bottle
Veilside Steering Wheel, black in color, could do with re trim, no boss kit $100
Veilside Gearknob, to suit nissan/mazda thread size, $60
Email me for further info as i dont come on here that often
i do have some other spare parts etc from a wreck, if you want anything in particular, email me and ill see if i have it.
[email protected]
cheers, michael
https://www.sau.com.au/forums/topic/67264-r32-spare-parts/
