Does anyone know much about Master Power Turbo's?
How do they compare to the other brands, Garrett etc?
Good Quality?
reliable?
I am looking at buying a Master Power T04E for my R33 so If anyone knows anything about them I would really appreciate if you could let me know what you think.
Thanks
https://www.sau.com.au/forums/topic/67275-master-power-turbos/
master power are from the same place as xs power turbos.
these are garret housings with cheaper chinese quality shafts, wheels, and bearings. they fall apart after a few hundred kms. a guy at tafe just built up his lowlux motor and put an xs power t3/t4 on it, after running the engine in, he gave it a boot and kablammo!!! the shaft snapped in half, lucky it didnt chew the comp wheel up.
stay away from them.
cheers
Linton
Master Power, have been around for 25 years or so, making plain bearing, old Garrett technology turbos in Brazil. The turbos themselves seem to be made well enough, but they are far from state of the art, technology wise.
I just gotta ask, are you really considering taking a ball bearing, water cooled turbo off and replacing it with an older generation, plain bearing, non water cooled turbo?
If you do make that decision, you will have to;
Block off the water feed and return lines
Buy a compressor inlet adaptor (the diameters are different)
Have an adaptor fabricated to fit the compressor outlet to the standard intercooler inlet pipework
Have an adaptor made for the wastegate actuator
Add up the cost of parts, plus it will take at least three times as long to fit. Compare that all up cost with the cost of buying a ball bearing hi flow, which is a far superior solution technology wise and will save money in servicing over its life.
Hope that is of some help:cheers:
Yeah Thanks Sydney Kid,
I know some people that are bringing a few of the master power turbos in and the price sounded good, T04E about 1250 to 1300.
(Of course they are the ones bringing them in so they only had good things to say about them)
but by the sound of it I would be better off getting my other option, a custom made Garrett 450hp turbo for $1600
it is ball bearing and water cooled.
Or you mentioned just getting my T03 high flowed. Which would you recommend?
Thanks for your help
The smaller T04 sized Master Power turbos sell for ~$US650, there are a few places in the US retailing them for that. No import duty (US free trade agreement), freight and 10% GST so they are making a reasonable margin at $A1,300.
If the Garrett is configured to fit straight up then it is comparable, but I suspect it will need extra parts and some fabrication. We get 265 rwkw out of the R34GTT with a GCG ball bearing hi flow, which is pretty close to the rated 450 bhp, so it's a genuine number. Plus it makes more power EVERYWHERE than standard. There are quite a few other RB25's with similar results, so it's not a fluke engine.
I am not a fan of taking standard internal RB25's over 450 bhp, some people do it and get away with it, but plenty more have had failures. For an all round performance (drag, circuit and road), almost standard response, ease of fitting and right up to the std internals limit, I have yet to find a better solution.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
