Hi guys, bought second hand gauges on my visit to japan and discovered today that I am one cable short... :D
The defi gauges system link one gauge to the controller box by one cable, then the same cable can then daisy chain that gauge to the next one and so on.
So, I need one of these said cables, quite urgently, otherwise does anyone know the defi distributor who might have these?
Cheers in advance.
see also my WTB, below in my sig ;)
https://www.sau.com.au/forums/topic/67307-defi-australian-distributor/
