I would just like to thank Greg Boyle from Autosport Engineering in Kirrawee Sydney for an excellent manual conversion job on my r34 gt-t. It only took two days and I was very happy with the result. Everything works well and he was more than happy to answer any questions. I chose Autosports because a member from the forums referred him and said he was the man for the job, he was certainly right. It took me more than 2 months to find a place that I could trust to do the job and in the end my patience paid off. If anyone is considering to convert than I highly recommend Autosports Engineering for the job.
Their business number is 9521 1388.
155 Bath Rd Kirrawee
He just did all my compliance/servicing/mod fitting on my GTR
Greg is top guy, I would recommend him to anyone. Definatley be going there for things to be done when I can, distance is the only issue :cheers:
has a nice demo car too :(
mark
