Hey guys, im having a lot of trouble with my r33,
basically when i first got it i was all excited cause i waiting 15 weeks for it and when i got it i had problems from day 1
basically when i first got it i would plant it and it would take off really fast then just die, like a boost cut, and i thought that was normal but my mate said no, so i didnt even end up getting my 94 r33 gts25det black nissan skyline that day anyway cause they had to check it out AGAIN
anywayz
they fixed that said it was a computer setting or something
i think they dun know shit but anywayz,
things kept happening time and time again
clutch got replaced with a brass buttom clutch and my flywheel redone
then my car was going slow, laggin, having trouble starting, so someone recommended fuel pump needed to be replace, OH YEAH IT DID?, they had a 2.0L fuel pump out of a non turbo car in my 2.5L Turbo skyline, performance lack,
so i got a nice aftermarket bosch 600 horse power one for my car, NOT CHEAP,
anywayz
all this been done
car running really good
but still doesnt start straight away, why it take so long to start sometimes,
not just that but
i be driving when its cold, like i will finish work at say 11 at night and come out to go home basically drive my car, it takes its time to start, then when it starts ****ing i take of and it like vrrrrmmmm vrrmmm vrrrrmmm like jumpie, like i have put my foot on brake then accelerator, brake acclerator etc...
boost cut
or something
dead coil pack
im ****ing no skyline expert
ask me about computers and i will tell you anything you want to know
but skylines i dont know shit about and thats why im on skylinesaustralia.com forum
so if anyone can help me it would be much appreciated
even if you can add me via messenger
its the same
[email protected]
messenger
or even email me
or talk to me on the forums
i just really need to sort this out
appreciate it guys
cya on cruise
1BTX293 (look out for me)
https://www.sau.com.au/forums/topic/67332-r33-doesnt-like-the-cold/
when u thrash ur skyline, expect shit to break. can garuntee u that just abt everyone of these boys have or will replace their clutches/belts/ pistons, whatever in the lifespan of their ownership. then again u could have scored a lemon. If ur from morley WA. then do a search for the workshops that sauwa endorses, can almost garuntee they will solve ur problem
Just go to the WA section of the forums and either look for a thread that addresses it or ask someone.
BTW it doesn't sound to me like he thrashes his car, sounds like he's saying he's had these problems from day 1. Sure if it's cold weather you should let your car warm up (for its long term health), but even if you chose to ignore that it should still start on time and not give problems in the short term.
Good luck with sorting it out.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
