  • Replies 52
I think you might be lucky.. as it's a day's work, if you know what you are doing, probably 2 if not. It's not something you'd choose to do for 'fun'.
I think v8man is pretty much ob the ball with the list of parts, as I'm just in the process of collecting them myself. He did miss tailshaft though, which is an important one (I paid $150 for my manual shaft)
ECU does not have to be changed, but thats been covered. Auto in manual req eCU change, manual into auto not. It will work anyhow, if there are any issues, change it later.
There is some basic wiring you have to do too with neutral switch and a few other things. I don't think you have to change the cluster.. maybe on R33 as it has the christmas tree auto thing in there. but R32 they are exact same (I have two clusters sitting around).
You will need to change your speedo sender too, for the different ratios - or your speedo will be out.
Does anybody know where you can get the selector fork from and boot? From memory it looks very similar to R31 one (nearly identical sized box).. but i didn't get one with my box :P
For R33 boys you're looking at about $2000 in parts, so it won't be cheap.. There is no place that sells the kits "complete" afaik so you'll have to hunt for a halfcut, wreck, or a wrecker (who will charge you big bickies).
Already for my cheap ass box, and rest of the bits on the R32, it's going to be up around the $1000 mark for the bits.
wasnt aware tailshaft was different....but i was ready for it as a lot of times they are...
catch can ....i can to that tomorrow arv i suppose.....after 4....50 bux it'll cost ya....
i hope you have all the bolts for it...other wise ill have to look thru my box of bolt and i cant guarantee ill have the right ones....
yeah i guess....off the top of my head you will also need hose clamps,,,,,,rather than wast you time...you should come round so i can check it out first, uncase there is more stuff you need to get.....that way it will be straight forward when i do it...
STZ automotive in Northgate are pretty good and they have extensive experience on skylines.
i don't have the number on me at the moment but its in the white pages too.
they are in Landy St Northgate.
they did my silvia rb20det conversion + manual conversion and a few other goodies.
How much was the conversion?
the R32 half cut = $2000
hybrid copy intercooler + piping $530
SR20 front brakes = $100
complete workshop charge (engine, wiring, exhaust hooking up, front brake change, intercooler mounting + manual conversion included) = $1500 - 1600
i get the car back anyday now, (closed for easter)
  • 14 years later...
On 15/03/2005 at 8:35 AM, V8skylineMAN said:
if you have ALL the required parts im sure i could do the job for you. a lot cheaper that a workshop...but dont get me wrong it'll still cost ya
Hey man I have a 2008 ford falcon bf I was wondering if you would be able to convert it into manual from auto, I live in Brisbane btw
Hey man I
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
