Not sure if its been posted already or if people have received it in there e-mails but anyways, I got it this morning and thought it was amusing.
Ferraris entire pit crew fired.
The Ferrari Formula 1 Team fired their entire pit crew yesterday. The
announcement followed Ferrari's decision to take advantage of the Australian
Government's Youth Opportunity scheme and employ people from Dandenong. The
decision to hire them was brought on by a recent documentary on how
unemployed youths from the Dandenong area were able to remove a set of
wheels in less than 6 seconds without proper equipment, whereas Ferrari's
existing crew can only do it in 8 seconds with millions of euros worth of
high-tech equipment. John Howard went on record as saying this was a bold
move by the Ferrari management, which demonstrated the international
recognition of Australia's employment practices under his Liberal
government. As most races are won and lost in the pits, Ferrari now have an
advantage over every team. However, Ferrari may have got more than they
bargained for......At the crew's first practice session, the Dandenong pit
crew successfully changed the tyres in under 6 seconds, and then within 12
seconds they had re-sprayed, re-badged, and sold the vehicle to the McLaren
team for a slab of VB, a kilogram of speed and some photos of Montoya's
girlfriend in the shower.
https://www.sau.com.au/forums/topic/67339-ferraris-pit-crew-fired/
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
