  • 3 weeks later...
I haven't looked THAT much into alarms/immobilisers as mine came with a kick-ass one when I bought it, but I do know you can get alarms and immobilisers that come with a turbo timer built into it :)
that might be an option for you
https://www.sau.com.au/forums/topic/6734-alarm-suggestions/#findComment-108976
If you wanted to get a tracking device, get Navtrack or Turbotrak (by BRANT) instead of Quiktrak. THey use GPS so work almost everywhere, whereas Quiktrak uses radio so only work in a certain range. I'm also looking at security options for when i get my R32, im hoping a decrease in insurance premium will make tracking worthwhile.
https://www.sau.com.au/forums/topic/6734-alarm-suggestions/#findComment-108977
when u guys say its compatible with turbo timer how do you mean?
how does it work
coz i rang brant and spoke to em and there alarms i dont think are compatible with turbo timers
and
it is illegal to have that function in your alarM?
how would it work by the way
would the car arm as it is on ???
https://www.sau.com.au/forums/topic/6734-alarm-suggestions/#findComment-109136
what i guessed (dont have a turbo to have a turbo timer,....yet) is that, you know how some alarms arm themselves after a short time when your car is off and the doors are closed? well i think the alarm can be set to arm after the timer has switched off the car.
my alarm doesnt arm automatically so its good when i get a timer i wont need to get my alarm redone :)
https://www.sau.com.au/forums/topic/6734-alarm-suggestions/#findComment-109140
I have an autowatch hooked up fine along side my hks TT
basically you can leave the car running close the doors, lock the car and arm the alarm.
once the engine shuts off normally the alarm automatically does the rest of the immobilisitation etc...
if someone breaks in while the car is still running on the tt, as soon as the handbrake drops the engine dies, and alarm goes off.
Seems to be a fairly flawless system..
https://www.sau.com.au/forums/topic/6734-alarm-suggestions/#findComment-109235
Some info I found:
NEMISIS - BRANT'S FLAGSHIP MODEL
Our NEMISIS model is specifically designed for those prestige & performance car owners looking for that extra 'edge'. Price-wise it is at the upper end but delivers a lot of functions and features not available elsewhere.
Features -
Remote codehopping operation
Six (6) inbuilt engine immobilisers
Separate PIN entry operation
External self powered siren
Internal high oscillating siren
Two stage impact detectors
Separate ultrasonic internal volumetric sensors
Passive (automatic) immobilisation
Connection to all doors, boot, bonnet, hatch etc
Keyless entry (if vehicle is fitted with central locking)
Electric boot release facility (if fitted)
Silent and audible on/off signal
Automatic door locking on engine start (no cost option)
Automatic re-arm/re-lock in case of accidental switch off
Mobile installation 6 days a week
Lifetime original owner warranty
Electric window power up operation (optional)
I have emailed them for a price :D
https://www.sau.com.au/forums/topic/6734-alarm-suggestions/#findComment-109321
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
