Hi, i have a R32 rb20DET and it is all stock apart from a 3 inch exhaust from the turbo back and a filter...how much can i safely boost it to (considering that i want the car to be drivable on the streets).
some people tell me dont go more then 10psi until you get a froun mount and others tell me 15psi is ok without a front mount. can i please have some clarification on this as i dont wana do any damage.
many thanks
https://www.sau.com.au/forums/topic/67379-how-much-boost-is-to-much/
its always going to be a contentious issue.
i would say stick to 10psi to be on the safe side. some say 12psi is capable on the stock intercooler, but is it worth the risk? others will say 14psi as they have run it like that with no problems...
the generally accepted rule of thumb on the forums is:
- stock turbo is good for 14psi (some have failed at 10psi)
- stock intercooler good for 10-12psi
- stock engine management only good for 10-12psi
i say take the weakest link and stick at that level.
happy boosting :(
Waz.
what waz said is what i feel is generally correct, but but in regards to runnign something like 14 psi on the stock intercooler is something i wouldn't do. It's just to small and will get heat soaked very quickly and doesn't have its same effiency after a few full throttle runs. It's best to stay around 10 psi and no more for daily driving.
many thanks
Ive got the same mods as ur self and im running 13~14psi without problems day in day out....
apart from the exhaust and air filter, everything else is stock
    • Aren't these run off of high voltage in OEM applications? Like 200+V. Or at least 48V in mild hybrids. At ~18,000 BTU ballpark nominal capacity the power draw is at what, 2.2 kW? ~185A is a pretty crazy amount of amps. At 200V it's only 11A. The 70A nominal kits with up to 100A peak draw I see for stuff like classic Porsches have pretty substantial compromises like shutting off at idle and not actually managing to keep the interior cool in hot conditions because they can only output like 6000 BTU. IMO if I had to pick what high amp draw component to retrofit to these cars I would start with the engine fan, not the AC compressor. You need an ~850-1000W brushless fan, something like this: I would love to see the data but I would bet that whatever you save by running the AC compressor in a more efficient regime with an electric motor you're probably losing to conversion losses anyways. It's not really like a clutch fan where you're losing power all the time even when it's nominally disengaged and it gets worse as it engages because the envelope tracking isn't that precise.
    • I am a volunteer marshal at the Grand Prix. As such, I get a "friend / family" ticket. It is a general admission ticket, valid for all 4 days. Anyone interested in my spare pass, please DM me. Ticket is "free, gratis and no expense".
    • agreed, the price vs gains it鈥檚 there.   unless you go china supercharger. Temu racing anyone?馃槀https://www.facebook.com/share/15nkfpsg7Z/?mibextid=wwXIfr that was one of the ones that popped up on my feed 馃槀
    • Bit of a long shot but if anyone has 4 of these laying around in new or near new condition. I will happily buy them off you.     https://skylinespares.com.au/product/stabilizer-door-glass-inner-new-8032404u03/?srsltid=AfmBOop6L5EgUFaHPHiVXoAhv5k8aJYwc77nGmoApp-hY03OiOsNVaOv Thanks
    • I'm wondering is the Toyota and Mazda "collaboration" could see that new Toyota ???G20 ??? turbo engine that they have been showing off recently into a future MX5, apparently it's good for 400hp out of the box That could easily, possibly, be much better than the last collaboration between Toyota and Subaru with the boxer engine in the twins
