Hey i dont know if anyone has seen these before but this unit can lock your front brakes without locking the back ones, but i beleive this can somehow make launching quicker for drags .. probably not much but may squeze a split second or 2 ..
It would save your back brake pads while doin lines, but we all have skylines here so doing burnouts isnt realy a problem. I just mentioned this item for something to talk about..
https://www.sau.com.au/forums/topic/67422-bm-launch-control/
Pretty sure they are two completely different things mate. How having only the front brakes engaged helps launch is beyond me as one foot is on the clutch and the other on the loud pedal.
Launch control units cut fuel and/or spark to let you choose a desired launch rpm and be able to hold the throttle down flat with the revs not climbing above the set level.
Launch control and a line-locker are two totally seperate devices AFAIK.
I know little about launch control although was under the assumption it interacts with your transmission and is possibly some form of stall-converter on auto or limits wheelspin (feel free to correct).
Line-locker on the other hand is as old as the hills and performs as follows: 1) driver presses brake pedal which in turn sends fluid to both front AND rear brakes thus engaging the caliper, 2) driver presses line-locker button (generally located on steering wheel on drag cars) and then releases brake pedal, 3) brake fluid remains LOCKED in front brakes thus keeping front calipers locked but rears unlocked, 4) driver warms tyres and engine via means of burnout as front tyres are locked (only useful in RWD obviously).
Watch Jap drag footage such as GT-R class and everybody rips the line-locker and bags the tyres prior to racing.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
