Hey i dont know if anyone has seen these before but this unit can lock your front brakes without locking the back ones, but i beleive this can somehow make launching quicker for drags .. probably not much but may squeze a split second or 2 ..
It would save your back brake pads while doin lines, but we all have skylines here so doing burnouts isnt realy a problem. I just mentioned this item for something to talk about..
https://www.sau.com.au/forums/topic/67422-bm-launch-control/
Pretty sure they are two completely different things mate. How having only the front brakes engaged helps launch is beyond me as one foot is on the clutch and the other on the loud pedal.
Launch control units cut fuel and/or spark to let you choose a desired launch rpm and be able to hold the throttle down flat with the revs not climbing above the set level.
Launch control and a line-locker are two totally seperate devices AFAIK.
I know little about launch control although was under the assumption it interacts with your transmission and is possibly some form of stall-converter on auto or limits wheelspin (feel free to correct).
Line-locker on the other hand is as old as the hills and performs as follows: 1) driver presses brake pedal which in turn sends fluid to both front AND rear brakes thus engaging the caliper, 2) driver presses line-locker button (generally located on steering wheel on drag cars) and then releases brake pedal, 3) brake fluid remains LOCKED in front brakes thus keeping front calipers locked but rears unlocked, 4) driver warms tyres and engine via means of burnout as front tyres are locked (only useful in RWD obviously).
Watch Jap drag footage such as GT-R class and everybody rips the line-locker and bags the tyres prior to racing.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
