Cedar & Cypress tree allergies?
Anyone in here get this bastard allergy? This is the 4th year I get this...and was perfectly fine before that! This year is really really bad and so bloody annoying!! My eyes look like I'm constantly smoking fat spliffs or something ....and constantly sneezing! Sooo annoying!
You can read more about it here:
http://www.voanews.com/english/2005-02-14-voa5.cfm
Hope nobody else has this as its a real pain!
https://www.sau.com.au/forums/topic/67427-cedar-cypress-tree-allergies/
No... I seem to be unaffected by hay fever... but famous last words hey? Alot of my students have come down with hay fever but they just grin and bear it - real Japanese style - and keep on going to work regardless. Not that it's highly contagious, but damn... I'd be taking at least a couple days off for sure if I had it.
Yup. I have it too. With most foreigners, if you are susceptible, it takes about 1 -3 years to develop the symptoms after you enter Japan. So for the first couple of years you may not have any reaction.
Antihistimines are good, but don't go on the piss after you've had them though.
You can also buy HEPA air filters and ionisers for your home, and they work really well.
IG
I've been here going on 5 years and I've never had it... I hope it stays that wat too!
They reckon that about 30% of the population either has the antibodies and/or develops the symptoms. If you haven't developed the symptoms yet, it is unlikely that you ever will. Count yourself lucky.
This year it's a bit weird for me. There's a hell of a lot more pollen around, but my symptoms are a lit milder than in previous years. I'm certainly not worried about this development. It's my last year here anyway as I am shipping out at the end of April.
IG
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
