Hey has any1 ever had problems with their housing fan cracking(fan behind da radiator)????cause wen i got my car checked out da mechanic told me i had to replace mine.....he said eventually the whole fan will crack to pieces......
And has any1 had problem will an oil leak due to a bad gasket/loose screw..???cause mine had a slight leak causing a burnt smell every time i turned da engine off.....i tightened up da screw but is dat sufficient to fix da leak????
https://www.sau.com.au/forums/topic/67471-changing-housing-fangasket/
