yep. Ahahahahahahahahaha. Suffer.
Actually I think this is a good idea. As an easily irritable motorist I'm far less likely to get angry with a P plater if I know they're a P plater.
I give P platers more room and am generally more considerate of them because I know how useless I was when I first got behid the wheel of a car.
https://www.sau.com.au/forums/topic/67474-p-plates/#findComment-1251858
mish, im a p plater, actually im currently a G plater and due to good behaviour im gonna b stuck with p plates for a whole extra year... mish...
are you serious, i was goin to op for good behaviour, but i didnt think i could last on it for a year. How long have you go to go?
https://www.sau.com.au/forums/topic/67474-p-plates/#findComment-1252304
double miish... P plates...
hehe... i've seen a few pplz with personalized plates,
they stick the P plate beside the plates so it shows
[P] EN15
[P] US51
still... no way with the P's!!! stickers are bad, and P plates are worse!
https://www.sau.com.au/forums/topic/67474-p-plates/#findComment-1252490
well QLD is one of the only states NOT to have had them.. and most states has had them for a decade or more.
I found it very odd that QLD didn't have them when i moved up.
Anybody on P's who has an import is really screwed now though.. they have something to clearly look out for and pick on. They do it in the other states, so it will happen here. Saves them trouble.
https://www.sau.com.au/forums/topic/67474-p-plates/#findComment-1252492
I heard it was as of 1st July or something like that. Definately coming into effect but not exactly sure when. They were also thinking of having cerfew and passenger restrictions for P platers also. Also not sure if they will be going ahead.
https://www.sau.com.au/forums/topic/67474-p-plates/#findComment-1253015
im pretty sure the passenger restrictions and or cerfew (if ever allowed), will be trialed in somewhere such as NSW before they are implemented Australia wide.
https://www.sau.com.au/forums/topic/67474-p-plates/#findComment-1253032
nah i havent seen many people with p's here..........maybe it's different in Scotland. if it's in England then i'm sure the SNP would have opposed it........
i think it's a good idea in QLD. i got my p's about 3 days before i went over seas, i can legally drive in oz (and uk too, but i cant find someone who owns an auto) but the gap between me getting my licence and actually driving on my own is over 1 year. i would like p's cause i'd hope other drivers would give me that extra leeway or room for error.........fat chance most likely i got SFA on my L's.......
https://www.sau.com.au/forums/topic/67474-p-plates/#findComment-1253074
I got about 5 months to go, thats y im not out and about much nemore, reasonably defectable car that stands out, i dont need attention atm. Have had a few close calls to but have been lucky so far.
https://www.sau.com.au/forums/topic/67474-p-plates/#findComment-1253382
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
