rev210 Posted December 3, 2002 Author Share Posted December 3, 2002 It's finally in !!!!!! What a difference! Is it faster ? Yep. Is the gear change faster and easier ? Yep. Does the boost come on quicker? Yep. Is the throttle response improved? Yep. Does it stall easy off idle? Nope. Do you lose lots of revs between gears? Nope. Has it lost torque? Nope. I say all this even with a bad exhaust leak probably killing off some of the power (thanks to me taking the exhaust/gearbox mounting bolts out of the cat and not tightening them back up fully). The clutch is just as soft and friendly as stock, maybe even softer and grabs very well. It's a fantastic design from Autoclutch, big thumbs up! Flat 13's here I come! :) Link to comment https://www.sau.com.au/forums/topic/6748-ogura-flywheel-and-ceramic-clutch/page/2/#findComment-102119 Share on other sites More sharing options...
GTS-t VSPEC Posted December 3, 2002 Share Posted December 3, 2002 Congratulations rev210, I'm glad you happy with the result, goes to show that the hassles of getting it in make it all the sweeter once it's done. Flat 13's sound like a good target figure, no clutch slip now, but probably more tyre slip. See'ya :burnout: Link to comment https://www.sau.com.au/forums/topic/6748-ogura-flywheel-and-ceramic-clutch/page/2/#findComment-102125 Share on other sites More sharing options...
rev210 Posted December 3, 2002 Author Share Posted December 3, 2002 Originally posted by GTS-t VSPEC Congratulations rev210, I'm glad you happy with the result, goes to show that the hassles of getting it in make it all the sweeter once it's done. Flat 13's sound like a good target figure, no clutch slip now, but probably more tyre slip. See'ya :burnout: I'm happy and relieved all at once. Gotta have a target even if a little optimistic. First I'll see how close I can get running the same conditions as last time so I can incrementally change stuff as I sort it out.That means: Changed : * clutch * flywheel Keep the same: *100+kgs of crap in the boot (no problem there I almost always have it in day to day) * 8 psi of boost * Same 205 tyres yum cha cheapo tyres (be it a bit more worn) I'll probably put the boost up to 10psi as the times improve. Having said all that I reckon the best fun at the drags is beating all those cars you don't get to race legally on the street but see from time to time. Link to comment https://www.sau.com.au/forums/topic/6748-ogura-flywheel-and-ceramic-clutch/page/2/#findComment-102132 Share on other sites More sharing options...
GTS-t VSPEC Posted December 3, 2002 Share Posted December 3, 2002 Rev210, What was your best time before the change? It will be interesting to see what difference is makes on the track. Jeez, they seem like awfully small tyres, I can give you some 15% tread 255/35's for 17" if you have rims to fit them on. I noticed about .4sec improvement between .5bar and 1bar of boost, but you have to keep the revs lower at launch. See'ya:burnout: Link to comment https://www.sau.com.au/forums/topic/6748-ogura-flywheel-and-ceramic-clutch/page/2/#findComment-102133 Share on other sites More sharing options...
rev210 Posted December 3, 2002 Author Share Posted December 3, 2002 Originally posted by GTS-t VSPEC Rev210, What was your best time before the change? It will be interesting to see what difference is makes on the track. Jeez, they seem like awfully small tyres, I can give you some 15% tread 255/35's for 17" if you have rims to fit them on. I noticed about .4sec improvement between .5bar and 1bar of boost, but you have to keep the revs lower at launch. See'ya:burnout: 13.8sec a few wed nights ago. Slippery track fried chicken clutch:D Link to comment https://www.sau.com.au/forums/topic/6748-ogura-flywheel-and-ceramic-clutch/page/2/#findComment-102136 Share on other sites More sharing options...
GTS-t VSPEC Posted December 3, 2002 Share Posted December 3, 2002 Well then a low 13 shouldn't be out of the question as long as your tyres can hold up.:burnout: Link to comment https://www.sau.com.au/forums/topic/6748-ogura-flywheel-and-ceramic-clutch/page/2/#findComment-102145 Share on other sites More sharing options...
rev210 Posted December 3, 2002 Author Share Posted December 3, 2002 The drama contiunes... Last night whilst attempting to tighten up the bolts on the cat. converter I managed to break one off! Now the exhaust leak is worse and I'm going to have to go to an exhaust joint to fix it :hellpisd: It appears my cat. is original as well so I might have to change it's done 90,000+kms now. Link to comment https://www.sau.com.au/forums/topic/6748-ogura-flywheel-and-ceramic-clutch/page/2/#findComment-102517 Share on other sites More sharing options...
GTS-t VSPEC Posted December 4, 2002 Share Posted December 4, 2002 Why dont you get the guys at the exhaust place to hollow out the cat and put a 3" pipe through it. The cops can't bust you as it will still look the same, or at least get a hi-flow one done. See'ya:burnout: Link to comment https://www.sau.com.au/forums/topic/6748-ogura-flywheel-and-ceramic-clutch/page/2/#findComment-102590 Share on other sites More sharing options...
macka Posted December 4, 2002 Share Posted December 4, 2002 Naughty naughty no Cat! poluting the atmosphere bla bla..... Thanks Paul for your help Ive sent you a PM. See ya tonight Link to comment https://www.sau.com.au/forums/topic/6748-ogura-flywheel-and-ceramic-clutch/page/2/#findComment-102613 Share on other sites More sharing options...
ix9 Posted December 4, 2002 Share Posted December 4, 2002 Originally posted by rev210 It appears my cat. is original as well so I might have to change it's done 90,000+kms now. What ? you had a stock cat on a FULL exhaust ? Link to comment https://www.sau.com.au/forums/topic/6748-ogura-flywheel-and-ceramic-clutch/page/2/#findComment-102615 Share on other sites More sharing options...
rev210 Posted December 4, 2002 Author Share Posted December 4, 2002 Originally posted by Strich9ine What ? you had a stock cat on a FULL exhaust ? Errr... yep stock, its even got the nissan factory heat sheild cover. Does anyone know how much restriction these stockers have? I'm going down to quick fit in morley to get them to have a look , I doubt they would want to punch a hole in it. I might just get a replacement while I'm there. Here's another pic of my 'installed' clutch and flywheel Link to comment https://www.sau.com.au/forums/topic/6748-ogura-flywheel-and-ceramic-clutch/page/2/#findComment-102658 Share on other sites More sharing options...
rev210 Posted December 4, 2002 Author Share Posted December 4, 2002 Here's a pic of my patent pending clutch alignment tool for tools:D Takes 5 min to make them with a length of dowl and some electrical tape. Link to comment https://www.sau.com.au/forums/topic/6748-ogura-flywheel-and-ceramic-clutch/page/2/#findComment-102662 Share on other sites More sharing options...
GTS-t VSPEC Posted December 4, 2002 Share Posted December 4, 2002 Macka and Rev210, I have a cat on mine but it is hi-flow, I'm probably polluting the atmosphere just with the shear weight of premium unleaded I use. I don't see the point of a good exhaust system if your still going to leave a large restriction in there. That's just my opinion, I'd got for hi-flow or straight pipe inside the stock cat. See'ya Link to comment https://www.sau.com.au/forums/topic/6748-ogura-flywheel-and-ceramic-clutch/page/2/#findComment-102667 Share on other sites More sharing options...
ix9 Posted December 4, 2002 Share Posted December 4, 2002 daym. I got a stock cat in mine too, looking to get a 3" hi-flo after christmas.. see how that goes. plus i still got my bubbly boost leak thing going on, so I gotta get that fixed before I do anything else... Link to comment https://www.sau.com.au/forums/topic/6748-ogura-flywheel-and-ceramic-clutch/page/2/#findComment-102670 Share on other sites More sharing options...
