Hello all,
in a couple of weeks my friends and i will be looking to do a bit of a cruise weekend, going somewhere distant from home (Logan City) and staying the night to come back on sunday. the problem is, were not sure where it is to go? :headspin:
so im after suggestions on where to go, where we could stay, and possibly things we could do there or on the way.
on thought is to go up north to sunshine coast, stop by Condalilly Falls for a BBQ lunch of sorts, some cricket or something eventful, stay in a hotel the night, maybe go clubbing/bar hoping (where are the main ones??) and perhaps swim the ocean the sunday before we head back home. :)
so if any of the local up there, or maybe down south, would know a scenic kinda route to drive with things to do and places to stay, perhaps even a bit further the sunshine coast (so about 3 hours drive?) either north or south, im open for suggestions :)
thanks!
:rofl:
shaun.
https://www.sau.com.au/forums/topic/67488-where-to-cruise-for-the-weekend/
if you're bringing your missus's with you, can i suggest a stop (or stay the night) in montville, scenic rainforests, lovely little chalet style accomodation, and cafe's etc...
EDIT:
here's a website with a bit of info about montville:
http://www.montvillevillage.com.au/
Its a nice scenic mountain drive to get there too, so it'll keep both of you happy :headspin:
oi matt wat are u doing sat nite man want to organise a lil cruise to the coast??
which coast are we talking about (gold coast or sunshine coast)?? I lose my license on monday next week so if we do something this is definately my last event.....
is byron,is good
Great hills in the back of Byron.
Stay outside of Byron if you like...
drive from, Brunswick Heads to Mullumbimby, then on to Clunes, Bangalow and down to Lennox.
Broken Head is a great spot but not much accom. nice beaches...
You'll find better maps down there, but here's a sample...
http://www.byron-bay.com/maps/shiremap.html
http://www.byron-bay.com/maps/regionalmap.html
Sunshine coast is ok, but I'd go south!!
PEAR
Why would it be your last event. You don't need a licence to be a passenger.
very true, my wording is incorrect, this is the last event that my present car will be on and the last event for a bit as a driver...
HAHA Seeya that Slide, 33NIZ, Chris and Dale someone else lives in Logan. Take That!!!
:):rofl::O:rofl::):rofl::rofl::rofl: :rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl:
you funny mofo
your right man we dont know what we are missing.
im sure some crazy bastard will start letting of flares and steel my wheels and plates :wassup:
we could probably also expect behaviour like riding onsombles down a hill and crashing into a drain :rofl:
GO LOGAN
    • Good points thanks. Unfortunately I can't seem to rename this or delete the topic. Seems like I'll ask the moderators to change it or delete it.
    • You might want to update the thread title.  V37 ≠ V36.  And it probably isn't a G37 unless it is 2012+ Ininiti or LHD.
    • Just a basic run down of the relevant bolt-ons. All e85 First graph 406.9whp is HKS GT-RS, HPI manifold, 3" bell mouth dump / 3" straight through fake cat / 3" all the way to the rear and no resonators, nismo 740cc, walbro 460, oem RB26 itb's, power fc, eboost2, Greddy Spec M fmic, poncams, Turbosmart actuator, splitfires, ARD 150amp alternator. Blue line is same as above but Blitz Dual SBC (before i upgraded to eboost2) and 100cell "high flow" cat. Red line is after installing eboost2 and the fake 3" cat (it's just a 3" pipe with a cat shell welded onto it). Huge gains in response, as can be seen. Black dots are a mates sr20 with almost identical setup but uses a garrett 2871 instead oh HKS. Next grapghn 466.6whp is same as above, but HKS 2835 Pro S with the larger .87ar turbine housing, the special HKS Pro S dump pipe into a HPI split dual 2.5" front pipe and the rest stayed as is. Red line is after I welded the actuator brackets. (It was originally bolted together and was moving a couple millimetres under load). Green line is obviously before I welded the bracket, no other changes. 100whp gain at 3750rpm, massive gain for such a simple fix. Third graph is my current setup, huge changes. 469.7whp R31house twin scroll manifold, twin TiAl 38mm gates, Forced Performance (USA) HTA3076 with 1.01ar twin scroll rear housing, Link Fury+ and loom by 12volt, PRP trigger kit and r35 coil kit with r35 splitfire coils, HKS step 1 vct staggered cams, new oem lifters and performance springs, 49mm itb's w/port matched Nismo plenum, twin walbro 460 surge tank setup + 1650cc injectors, HKS Type R S13 600x300x103mm fmic, individual egt's, 4" turbo back with no resonators or cat and AES true straight through muffler + 4" butterfly off the dump pipe lower 90° bend. It's a preliminary tune with no boost control with using 20psi gate springs and 4" butterfly closed. Once body loom and PDM is compete, will go for 30psi tune.
    • Power light apparently functions as a transmission error light, you can try the power sequence to read any codes from the transmission control unit.
