Im currently considerig buying another rb20, the compression results the seller gave me are as follws...
1-130
2-135
3-130
4-130
5-130
6-135
Is it just me or are these numbers a bit low. Im not worried about the difference seen in no2 and 6. I just thought a healthy engine should show compression of maybe 150 - 160? Although seller assures me these number are spot on? test was done on a warm engine
Thanks for your time, Tim
https://www.sau.com.au/forums/topic/67557-rb20det-compression-results/
i have a 1989 rb20det eccs in my HR31 Gts-x
did compression test the other week. the engine is stock, runs normal boost, and runs beautifully. ran 135 on all 6.
my other mates' rb20det silvertop is bout 113 on all 6 and it's unhealthy.
That's very close to what both my RB20's tested at recently..
My gauge has always read low, and seems to read 130psi on a healthy engine. So I wouldn't be too worried.
As long as they are within 10% everything should be fairly fine.
my rb20det with 160 kms on the car had it around 150 to 160 with most on 155
but apparently the engine was rebuilt bout 30thousand kms ago
but i remember somewhere it doesnt really matter as long as there isnt a big difference between the cylinders
might not be a bad idea to pay to get it tested by a mechanic you know
just to elaborate on what i just said th ough, a comrpession test won't pick up everything
i've comp tested ca18det's which were piston slapping pieces of crap and they pulled 165-170psi all round
i've also tested an ex-drifted sr20 which got 165psi but engine ran nice and smoothly, just had been driven on rev-limiter for most of it's life...
  • 5 years later...
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
