Im currently considerig buying another rb20, the compression results the seller gave me are as follws...
1-130
2-135
3-130
4-130
5-130
6-135
Is it just me or are these numbers a bit low. Im not worried about the difference seen in no2 and 6. I just thought a healthy engine should show compression of maybe 150 - 160? Although seller assures me these number are spot on? test was done on a warm engine
Thanks for your time, Tim
https://www.sau.com.au/forums/topic/67557-rb20det-compression-results/
i have a 1989 rb20det eccs in my HR31 Gts-x
did compression test the other week. the engine is stock, runs normal boost, and runs beautifully. ran 135 on all 6.
my other mates' rb20det silvertop is bout 113 on all 6 and it's unhealthy.
That's very close to what both my RB20's tested at recently..
My gauge has always read low, and seems to read 130psi on a healthy engine. So I wouldn't be too worried.
As long as they are within 10% everything should be fairly fine.
my rb20det with 160 kms on the car had it around 150 to 160 with most on 155
but apparently the engine was rebuilt bout 30thousand kms ago
but i remember somewhere it doesnt really matter as long as there isnt a big difference between the cylinders
might not be a bad idea to pay to get it tested by a mechanic you know
just to elaborate on what i just said th ough, a comrpession test won't pick up everything
i've comp tested ca18det's which were piston slapping pieces of crap and they pulled 165-170psi all round
i've also tested an ex-drifted sr20 which got 165psi but engine ran nice and smoothly, just had been driven on rev-limiter for most of it's life...
  • 5 years later...
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
