Please evaluate my series 1 rb25 rebuild plan and help me fill in the gaps as well.
I lost 3 cylinders after tuning. Got 40,90,60 compression on them... going to have the motor rebuilt here in the US.
I have searched thoroughly on the site but I'm still in the fog about some things:
RB25 Buildup Plan:
-Bottom End:
Metal Headgasket: what mm thickness?
ARP Head Studs: Same as SR Main Studs?
Wiseco RB26 Pistons 86.5mm Comp=8.8:1 or CP Pistons 8.5:1
Pauter RB26 Rods: .827” Pin Dia
Rod Bearings:?
Main Bearings: ?
-Maintenance
OEM Waterpump or N1 Waterpump ?
Power Enterprise Timing Belt (or Greddy or whoever)
Nismo Thermostat
ARP Exhaust Manifold Stud Set
OEM Full Gasket Kit (already have)
Fyi: Motor will be handling 400-500whp
Thanks a ton!!! ,
Daniel
R31 nismoid,would the stockie head gasket be enuf for 400-500rwhp.reliably speaking?
If you are hitting the tracks things like oil coolers come in handy.it's a reliability thing.
If you go r31nismoid's way for a rebuild,and it is reliable for that type of hp,then,you wont need forged rods,and you could spend it in other places like a set of cams etc.
Also need a N1 oil pump.
I too would stick with a factory head gasket, i have seen a RB25 pull over 330rwkw on a conservative dyno with forged pistons, a preped bottom end and stock gasket. Two year running without a problem and still going.
Get new stock bearings, the N1 oil pump will ensure there is enough oil to lubricate them.
Use a metal headgasket, the thickness will depend on the pistons and head cc's so you can decide that once bottom end together.
If you use rb26 pistions you need the rb26 crank as well as it has 2mm more stroke therfor the pin height on the pistions is different. SO just get pistons for rb25 and i would say 8.5:1 comp.
I believe ARP have just relased head studs for rb25 head, pretty sure sr is diff as they have been avliable for a while and we couldnt use them then.
RB26 rods are good for around 450rwhp with some rod bolts and prep work, but in the us for the cost any forged rb26 rod will do the job.
Use std nissan bearings, along with N1 water and oil pumps
If your using a rb25 head at 500 rwhp you will need cams, and springs deffiantely, and i would also add valves and solid lifters to the list if you wont a safe reliable motor, at 400rwhp should all be good std, but 500 very unlikely in my opinion
So, what about piston size? 86.5mm is the size that www.phase2motortrend.com lists for CP Pistons for the RB25.
And it IS ok to get the Pauter forged rods designed for the Rb26? www.pauter.com/nissan.htm
And std nissan bearings will do? Do I just order a set for main and rod in general? Or does my engine builder need to measure anything first?
I'm thinking about going with a stock height metal headgasket, such as 1mm or 1.1mm any thoughts?
I've contacted RIPS about their Rb30 blocks to see the price, to see if it is worth it to go that route.
Thanks for the help!! :)
Daniel
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
