Hi there guys, just trying to find myself a new replacement set of bulbs or just bulb for my r32.
The bulb is H3C is that right?
Any suggestions/reccommendations would be appreciated. I tried that little 'car accessories' shop in carousel, they said they ran out.
Anyways, cheers.
I had success with my bolbs at Carquest in East Perth, Shop 9 Piccadilly Square, 5 Short St. They have website but you prob wont find the bolbs listed on there www.carquest.com.au
I'd go in there, I hunted everywhere and found most of the stuff there.
Ciao!
Im pretty sure mine are not H4 (r32 gtr), as ive tried those and its a total different design, my mechanic said they were H3C - i think he said they were same as s13 sil, not 100% sure but its def not H4 for mine.
Most places i found dont stock the H3C.
Thanks every one for your help, cheers.
When trying to find parts for an import ure best bet is to ripp it out and take it in and match it up with what ever they have, usually they have some crazy ass number on the side that gets you nowhere but the part is exactly the same as a standard part from a commo or something. just a bit of advice coming from the guy who get weird looks when he says
Me- "its a nissan auster"
Repco/any car guy- "Nissan what?!?!?!"
My right hand indicator bulb has blown twice in two months :D
Stop overtaking people so much, then you wont need to use your right indicator so much (haha)
speaking of blown bulbs, my ute has chewed 3 LHS bulbs in a month....sus, must be something im doing wrong
hey speaking of bulbs? i have a gtst, its has park light, projector and high light in one cluster (like gtr) but are those bulbs (main light, projector) H1 or H3C cos i am trying to find white/blue lights for my line? any advice anyone?
Pretty sure it would be h3c, but i could be wrong, the H3C just has 2 big prongs on the bottom, just do what the others said and rip one out and take them out and about.
As for blue/white in H3C - i found them virtually impossible to find in Perth, maybe some where east has them readily available not quite sure, i found them hard enough to find 'normal' globes in the H3C pattern.
if you really want the blue/white look, id personally go a HID conversion, theres a bloke in the Forsale/parts section selling them for about 350-400 i think. Id pick up a set straight away, if i didnt have to buy so many uni books this semester :P
neways, good luck :)
  • 4 weeks later...
ok, i was looking at ebay, is there any difference between H3 and H3C? just want confirmation cos they do sell blue/white lights in both these codes..
Yep, they are different - take a look at www.narva.com.au/Globes_16.html and you will see the difference.
The main difference is that H3 has one prong, whereas H3C has two prongs (positive and ground).
My r32 has H3C bulbs in them aswell, but i was told that you can put in H3 and just attach it using the positive side of your plug. In saying this, does it mean that the H3 (and the H1 for that matter) doesn't need a ground wire since they only have 1 attachment?
Most companies only stock the standard light colour for the H3C, whereas you can get blue, white, arctic blue etc in the H3.
Anyone tried replacing the bulbs like this?
Just replaced my H3C bulbs with H3 bulbs...
Since the h3c bulb has 2 connectors and the h3 has 1, all you need to do is solder a piece of wire to the metal base of the h3 bulb and attach it to the ground wire in your headlight loom. The other wire just plugs into the positive side.
**The headlights that normally use h3 bulbs are already grounded hence no need for an extra wire.**
Works perfectly. :(
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
