Hey guys
went to willowbank test and tune last nite
after doin a 16.1 last time completely stock AUTO
i have improved abit with the help of a FMIC
avcr controller set on 10psi
CES racing split dump .
My time i did last nite was 15.2 with a .640 reaction time .
im off saving for my next lot of things to do to make it quicker
series 1 1993
had 122.3rwkw stock
and after those little mods it did 166.9rwkw
so slowly moving up .
Would this time that i did be accurate to the dyno rating 166.9?
considerin the reaction time and all of that?
my 60 ft time was 2.356
and did 91mph.
so yeah dont know whats goin on there then.
i'll get the car looked at and do what needs to be done
next thing is injectors, fuel rail, fuel pump, cams,
trans cooler, stg 2 quick shift, highflowcat, afm then turbo.
so should be gettin a bit betta from then
well done but im sure you would like to do better. Do you only have a dump pipe with the rest of the exhaust stock?? If this is the case then that will be a big restriction.
Also did you launch the car just by planting down the foot in 'D' or did you stall it up as far as it can go then taking off right when boost comes on??
Good stuff Mate , keep pushing it :)
My auto ( when it was stock turbo & ecu ) made a best of 13.4 @ 106mph (280 rwhp)
I didn't lunch an auto until mid 300s rwhp , & even then it was only heat that killed it!
I'm trying "Redline racing ATF" now ( with a bigger cooler!) , I'll keep you informed.....
GO THE AUTO!
when i went down the quarter
i stalled it up to about 2500 and .4 or .5 boost in 1st gear
then changed to 2nd and drive
Should i try goin down in just drive ?
I have CES racing split dump 3inch
Catback 3 1/4 hyper Medallion exahust
AVCR controller set on 10psi
600X300X75 hybrid intercooler
K&n panel filter
APC did a compression test and found the 6 cylinder was 130 and the rest were 150
I havent been in another auto yet, but it feels like my gearchanges between
2 and 3rd are pretty slow or is it just normal.
pulled a alright skid though hahaha.
What other things should i be lookin at to get myself in the 13's bracket?
  • 3 weeks later...
I aslo have an auto and am about to install a Greddy Profec B-spec II. I want to set the high setting ti 11psi. Will it be OK to have it on high for the entire race. Should I launch on low then go to high. Mines all whell drive so I dont need to worry about traction. Ill have a bigger transmission cooler in by the next meet.
My time i did last nite was 15.2 with a .640 reaction time.
Your R/Times don't count. The timer starts when you leave the staging line and cross the finishing line (otherwise most rotary cars would be doing 2min 1/4's :))
my 60 ft time was 2.356 and did 91mph.
. With some more experience you will easily drop this to around a 2.1sec 60ft which should put you in the mid to high 14's with no mods at all.
bazr33:
Well done on the time. As everyone will continue to tell u....practice on your 60ft times.
Did you have your Power button on & O/D 'off'? Coz I believe that helps with the launches & gear changes.
Gear changes normally are pretty slow in the auto (approx 1 sec....zzzz). If you’re interested, currently theres a group buy for an upgraded valve body (shift kits) from M/V Automatics - highly recommended & will give the manuals a run for their money.
As HR31 mentioned, do the car a favour & get yourself a high flow cat immediately!!! & if after that, given your mods, your tuner cant tune you over 170rwkw, I'd seriously look for a new one.
For a helpful comparison guide search on the drift & drag forums (the ones by 'benm' are insightful). All the best mate :)
burkey22:
I believe with a fairly dead stock Stagea you can safetly tune upwards of 10-11psi - (dont know your mods though). If traction on your launches isnt an issue just stick it on hi.
For a helpful comparison guide search on the drift & drag forums (the ones by 'benm' are insightful). All the best mate :P
12mths, 30 runs, ~$3,700+ spent and only a 0.5sec improvement.... Yup you'll learn lots from me :)
  • 6 months later...
i did 15.1 at wsid. auto r32 gtst 3" exhaust,pod filter and 11psi.
O/D was OFF and power was on,even had my mirrors folded in.
can anyone help with launches in fairly stock auto's? at what rpm should i change to 2nd? it feels like it should change earlier,but it likes to redline.
Does manualy shifting the gears make it change quicker? or is it an illusion?
Edited by RSTME
Go the auto
stalling up in N and smaking it in to drive and i through you would leave your gear box at the start
Greddy e manage with ignision harnes + wider tyers
out of interest i have a 250 rwhp auto
how would that go i wonder
james
Sad to say it but thats still slower than a stock off the showroom floor 265 powered auto 1973 valiant sedan.
Good to see you getting some improvement though..keep it up
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
