Curious if any one knows if i put on after market bigger dump pipes it will increase perforamce and less lag..
Also my car is running very rich im assuming its the o2 sensors would this be the case or could there be another factor causing this.
One more for ya when i run 1 bar or 1.2 bar of boost my car surges is this due to not enough fuel getting there.
any help is much apreacitated,.
https://www.sau.com.au/forums/topic/67600-32-gtr-dump-pipes/
1. Curious if any one knows if i put on after market bigger dump pipes it will increase perforamce and less lag..
2. Also my car is running very rich im assuming its the o2 sensors would this be the case or could there be another factor causing this.
3. One more for ya when i run 1 bar or 1.2 bar of boost my car surges is this due to not enough fuel getting there.
1. R32GTR's have not so good dumps, so an upgrade is beneficial.
2. O2 sensors are irrelevant most of the time, they only run closed loop for idle and cruise. All R32GTR's I have seen benefit greatly from a tune, chip upgrade or ECU replacement (Power FC is the go)
3. Try new spark plugs with gaps at 0.8 mm.
Hope that is of some help:cheers:
do the 32's,33's and 34's have diffrent dump pipes to eachother?
R32 and R33 GTR's basically use the same cast iron dump pipe design and they are a bit restrictive. OTOH R34's use a thin-walled, welded stainless steel construction which have a larger bore and so flow better - definately an improvement, probably similar to some aftermarket designs.
I'm certain that both 33 and 34 dumps are the same. 32 are 60mm, 33 and 34 are 70mm....big difference in total flow.
If you want a set of 34 dumps, Powerplay in Sydney have at least 2 sets second hand
The R33 ones I had in my hand a few months ago looked identical to my R32 type. I didn't take any measurements, but were certainly the same material. Perhaps late production cars were similar to R34 (?? - shrug).
Anyway the R34 dumps I have now are definately an improvement, no doubt about that.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
