Just keep in mind that EPA rats have also something to say about o2 sensors, so make sure it is in right place, and 100% operable as the rats at EPA have acquired a new computer that anylizes everything and shows a graph of how your o2 sensor is operating.
However, it is good for the environment, but also makes a difference in economy, i get around 50k out of a full tank more since i replaced the o2 sensor.
And as 'GTS4nMore' said, dont confuse the o2 sensor with the exhaust temp sensor, to complete different things, yet so similar in shape.
there is no obd ii software for skylines in oz, u can tell it its a 300zx and some things will work but the rats as u call them cannot do jack about it because its inaccurate and not for the right model car.
Well mate, i dont know about you guys in Brisbane, but down here in Melb have upgraded our systems.
I just went for EPA a few weeks ago, and failed it, he showed me the graphs on the copmputer that test the o2 sensor.
It shows a complete analysis of the things they look for, and in my case the o2 sensor was operable but wasnt 100% like it should be, he asked me about my fuel consumption etc etc, i had to replace it Costed me $155 for the sensor.
2nd pass, it passed no worries.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
