Just keep in mind that EPA rats have also something to say about o2 sensors, so make sure it is in right place, and 100% operable as the rats at EPA have acquired a new computer that anylizes everything and shows a graph of how your o2 sensor is operating.
However, it is good for the environment, but also makes a difference in economy, i get around 50k out of a full tank more since i replaced the o2 sensor.
And as 'GTS4nMore' said, dont confuse the o2 sensor with the exhaust temp sensor, to complete different things, yet so similar in shape.
there is no obd ii software for skylines in oz, u can tell it its a 300zx and some things will work but the rats as u call them cannot do jack about it because its inaccurate and not for the right model car.
Well mate, i dont know about you guys in Brisbane, but down here in Melb have upgraded our systems.
I just went for EPA a few weeks ago, and failed it, he showed me the graphs on the copmputer that test the o2 sensor.
It shows a complete analysis of the things they look for, and in my case the o2 sensor was operable but wasnt 100% like it should be, he asked me about my fuel consumption etc etc, i had to replace it Costed me $155 for the sensor.
2nd pass, it passed no worries.
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
    • These arrived today! Sadly I'm going to probably be smart and enjoy the car as is over the summer/sunny period and save the ~2 weeks downtime it'd take to swap the heads over and tune later in the year. Maybe. It's going to be pretty damn tempting seeing these bolt on funs just sitting in storage when they're ready to go. There's a non-zero chance I end up @The Bogan'ing it.
    • MZ11 Toyota Soarer in Iwata, Higashi Osaka
