One has to wonder if the turbo you are running is better suited to the rb20 than the HKS2530.
It would be very interesting to see back to back dyno runs.
Well this is a little off topic.. so... this turbo on the rb30 with the larger exhaust a/r might be quite a good responsive thing. :D
  • Replies 101
Ok, so i know the rb25 (r32) head uses same injectors as R32 gtst, someeon mentioned changing over to GTR items later on, the R32 gtst are high impedence and the gtr low impedence, does this make a difference/complication......will aftermarket computers handle this?? Whats the go with injector impedence. Coz the above mentioned injectors are both top feed...that much i know.......
Cheers
Geordie
mr_rbman,
For engine mounts head down the Shaun at Boostworx.
I bought my R32 RB25 head 2yrs ago from Adelaide jap for $750.
Take what Adelaide Jap say with a pinch of salt as they really don't know what parts are from what car.
They claimed my RB25 head was a R33 RB25 as the R32's didn't have a RB25 lol.
This was 2yrs ago so they may be a little more informed these days. :rofl:
engine mounts i will do myself as i am a boilermaker and things like that r a piece of piss, i hope to do most things myself minus the wiring up (no idea with electrical things) and the tuning which i will be seeing Shaun at Boostworx for!
Never deal with Adelaide Jap, have had the same experiences as u with them and will never go to them again!
Its a lot of money to get so little power, i mean POWAH. But if i could be farked i have priced an RB30DET for about $6,500, thats with cams, pistons and rods. $7,000 with a bit of porting
Then i would need to get my TD06 rebuilt and hi-flowed using either a 25G compressor or a GT30 wheel (and back to 10cm exhaust housing) About $1400..RB25 gearbox and twin plate clutch with modded tailshaft. $3100
So to go from 235rwkws to 335-350rwkws it will cost another $11,000
This is not an unusual question faced by R32GTST owners, thinking about RB30/25 in their car. So it is releveant to this thread.
Have you worked out how much you could sell the RB20DET for, complete with turbo, clutch, gearbox etc? Basically everything that you don't need. Keep the PFC, intercooler, exhaust, AVCR etc. Basically everything that complements the RB31.
Secondly, 350 rwkw's is a bit low for a $7K RB31, more like 400 rwkw. And at Philip Island you can use it, you were there and saw the blue car utilise that amount of power to win a National Championship.
It is horses for courses:cheers:
Tunned my car a bit more yesterday, my RB30det made 290 RWKW on 19.5psi, still using the stock RB25 n/a cams, and stock VL bottom end. Cant wait to get some decent cams in it.
That's getting up there in both power and boost. What's the A/F ratios look like?
:cheers:
Joel-cams im getting are tomei 260 degrees 8.8mm lift for both inlet and exhaust, which makes a fair improvement over the stock items.
SK- I set the A/F ratios to run at flat 12:1 at full load, using bosch o44 and rx7 injectors. Its a fair bit of power for a stock motor to handle, be interesting to see how long it lasts. Ive kept the rev limit fairly low at 7000rpm.
Sounds OK, just don't be tempted into running a "just bit more boost" or "if I lean it out a little bit I can get to 300 rwkw". Resist the temptation.
You will find the cams make a heap of difference. I will be interested to see how much the boost drops with the increased efficiency.
:thumbsup:
SK- If i was to run more boost with the correct a/f ratios and ignition timiing , do you think the motor would handle it??
Joel- On the dyno it makes peak power at around 6000rpm, and starts to drop off, but on the road its hard to notice this, and it seems to pull hard all the way to 7000rpm. not too sure why.
Darren- The tomei cams are RB20det cams, they also fit the rb25de.
valve float/bounce = pump up. :thumbsup:
Sounds good Sky30, peak at 6000rpm is a nice rpm point. :rofl:
I'm sure you have seen this dyno graph of a GT30r.
The 3ltr definitely looks like it needs that better flowing exhaust housing to get its higher rpm VE up there to prevent power flattening out.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
