Rb26 is still nearly 1/2 a litre less than Rb30, torque is still gona be a fair bit less.. All 3 boxes i destroyed had stripped 3rd gear, every time it happened i was accellerating hard in 3rd, then BANG.... One decent R33 box is cheaper than several Rb20 boxes.
  • Replies 101
just curious how would this conversion go in a A31 Cefiro? and gearbox wise i've heard that the best gearbox to use for a cefiro drivetrain conversion is a VLTurbo MX7 gearbox because it runs a cable speedo drive? and out of the MX7 and the R33 which is the better box would they handle alot of power and which one 'feels' the best for those with experience? cheers
do a search for how much they are. (~$1500) You just need one in good nick and it will last. No it wasnt difficult to put in, because i bought the setup out of another r32 (came with tailshaft modded, gearbox mount, and speedo drive modded)
Yes, i was running the rb20det b4.
heard of that. ;) They say because you are driving the car on SA roads, YOU are still responsible for it. They still defect it no matter what....
Nope, Commonwealth/State Law doesn't work that way, if the car is legal in Vic they can't defect it in SA. Take the defect sticker off and post it to them, with a thank you note of course.:D
The R33 gearbox feels alot smoother than the MX7. Most MX7 boxes have got high kms on them, there usually noisy and notchy to shift gears.
I used the stock r32 tailshaft and got a VL turbo yoke (or R33 turbo) welded on the front, overall length was the same.
SAPOL do what they want Gary...they can defect a car with interstate rego, and have done before.
Sending them the defect sticker will result in a nice fine as well....
I don't care who they are, they can't issue a defect notice on a car that is legal in the state it is registered in. This was tested many years ago in the Federal Court, Queensland had different registration laws with regard to extra lights. NSW tried to defect the trucks carrying the extra lights (that were legal in Queensland), they lost.
This case (and few others) is the reason why all the States signed the national agreement on common ADR enforcement as provided by DOTARS. SA has broken that agreement, if anyone takes SA to the Federal Court they will win.
A copy of the agreement is availabe under Freedom of Information from DOTARS.
:D
Im on your side Gary...when I get my car finished i'll be taking it interstate to more than one place to have all the ADR tests etc done to make sure its legal....
Ive had a cop on a bike pull up next to me and say "if i hadn't just worked a 13 hour shift, i'd defect you for your blow off valve". Then the lights went green, and he took off (from a right hand turning lane) and pulled infront of me to continue stright down the road.
Now without seeing my enginebay, how did he know i had a blowoff valve? And yes I do still have the STANDARD blowoff valve installed in the car.....WTF!!!
Its a revenue raiser for SA, and things are not going to change here (cops issuing defects) until this state gets WOF checks like other states. Until then they do what they like.....have a read of the regency thread in the SA section to see the BS they have gotten away with...(defecting ADR approved steering wheels etc)
I havent had any trouble with them as of yet (touch wood) but believe me i will be taking it as far as i can if and when the time comes....
/end rant....back on topic :D
Picked up my bottom end today, pretty good score i believe! Its a 1988 R31 bottom end with only 168,000kms! Looks to be in great nick, will start taking it apart soon and giving everything a good clean and inspection. Manged to score it for $150
Finally the journey of the RB30/25 begins! (8/4/05)
I guess we'll see how long it takes but i know that i can't wait to turn over the key!
Now you just need an engine stand. :D
I'm heading up my oldies tomorrow, I will grab it.
cool, my mate got his off Ebay but i reckon the one u got is better. Have you thought about a price yet? if so let me know and we can discuss me picking it up or whatever. Will it fit in the back of my 32?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
