Phoungy, what's up????
It probably would just make it easier to buy a manual, instead of having it converted from automatic, but if you want to go that way read through this thread - http://www.skylinesaustralia.com/forums/sh...ead.php?t=63000
The difference in price between manual & auto would probably be lost with the conversion price anyway, although you would have new components.
just read the thread, but im really serious importing a 4 door skyline, prob is most of them are autos, hence manuals are rare and expensive.
it is an option that im willing to take since auto arent thrashed as bad as some manuals, but if any1 knows any local workshop that does it, plz help out.
I'm in the process of importing a 4 door manual R32. Just be pacient, look through the auctions for a suitable one put a bid on and wait. It may take a while to find one but you'll be happy when you buy one, that you spent the time looking.
Took me 2 months to find a suitable one through trying and bidding on an average of 1 car every week and I'm happy that I did. We'll just have to wait and see what condition it is actually in. :)
Thanks for the plug Bam Da Man but that is for a 180sx or R32.
The box alone for an R33 GTS-T is around $1300-$1500 plus all the parts so the conversion would be closer to the $3-$3.5K depending on clutch.
Cheers
Ken
I did a manual conversion on my r33 and did it all my self... It is a fairly easy job to do and works out cheap if you do it the way i did it.........
I ordered a 33 halfcut (manual) from a place in wangara (pm if you want the details as this place doesnt like to be known about) for about $3500, swaped boxes and sold the halfcut here for $3500!!
The conversion is simple, you and a few mates can change the flywheel and lift the box in. The pedal box is a bit fidgity but if you persist its all ok. You dont have to remove any of the computers as it all adapts well.
The only electrical things you have to sort out are the reverse lights, speedo and neutral start switch (which i just looped together), But i have the way i did it written down if you need it.
Everthing else just bolts in (except for a hole you need to drill for the master cylinder)..... And the beauty of a halfcut is you have all bits to make yours a complete manual.... nuts, bolts, correct dash, centre console, gear boot etc etc.....
Saved me 5000 when purchasing the car, not that i wanted the manual at the time, it just happened that i annihilated the auto haha :)
Mike
SL33KGTS thanks for that advice, seems like a good idea and might save me sum cash in the long run cuz i might need sum extra parts in the future.
as for swapping it mysef, the only clutch &tranny i ever replaced is on a datsun (81) and that just a straight swap of the tranny and clutch that requires a shit load of upper strenght, becuase i didnt have a ramp.
dont get me wrong, i love doing things myself, but i doubt ill know how to get the peddal in there. and plus i doubt i have the rite tools
cheers guyz
Ps G0DF4Th3R whats ken's number
I had my four done bout 3 months ago. Can't conplain just a few simple things to iron out yet. Like when u convert using a auto speedo it reads 60 kms at 110. I just put a manual speedo cluster in and now 120kms is 110 accordin to gps. Also still got to get the reverse lights hooked up.I got a r34 box put in and it has cost me around the 3g mark but i couldn't be happier. Still worked out cheaper for me to do this then buy and manual and i have a 34 box ;) so much nicer. I have a Phone number of a guy that can do the conversion if u are intrested.
The autos in the 33 are extremely strong and i know of a few with stage 2 shift kits and 2.5 to 3 stalls....
From factory they have a failsafe function to prolong life. Everytime the trany shifts, the computer causes a missfire in the fuel/ingnition system so that no power transfers through the box at that time.... it sucks badly.... but i found a way around it: pump the gas pedal just before change (ie off then on) and she used the smoke into 2nd!!
Another advantage is the snow mode. The snow mode stops the use of 1st gear (unless you are manually in 1st) for slippery conditions..... so when you stall it up, put the stick in 2nd and it stalls in 2nd...... more boost no spin. When the light goes green, drop it into 1st and you'll have full boost. It is litterally like dropping the cluch in a manual ;)
Unfortunately as a consequence i destroyed the box after 6 months of hard driving..... unlucky hehe
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
    • Good question, I don't really know tbh...I'm pretty stock thought, where could I check this?
    • This. I'm confused by the whole discussion. The only reason you would have a car with e85 only if it was track use and you only ever used e85. All other use cases you add a flex fuel sensor, do the flex tune (you only need to do a couple of % and then interpolate the rest) and then you put whatever the hell you feel like including a mix in the tank and it just works. Want a long drive? fill with 98 Want max zoom? fill with e85 Got a half tank of 98 then find e85 somewhere? Throw it in.
