hi everybody. i am just wondering if anyone knows what the sunvisor or sunshade on at the top of the driver's side is talking about, its in japanese. All i can see is its talking about exhaust overheat indicator. Anyone knows what it is about?
just unplug it mate. it won't cause any negative effect. the sensor's only funciton is to light the warning light when it gets too hot., or you could just remove the bulb ;)
