Hey Guys,
I should be picking my car up today or tommorow, but the pod was stolen. Can anyone tell me the size of the piping on the air box side of the AFM so I can get a pod that will fit?
I was gonna get a blitz or whatever till I saw they were $170, I can get a cheapy from repco for $30....so I am gonna do that, But I need to know the size of the intake...
Also..anyone know the SR20DET's? If it's the same I will just borrow a mate's to get it home (I have ordered a stock airbox, but haven't recieved it yet)
Cheers
Chris
https://www.sau.com.au/forums/topic/67655-rb20detsr20det-afm-inlet-size/
Doesn't matter, I sorted it. FINALY have my car.
For future searchers - There isn't a pipe like I thought, the AFM is a flat end with holes for mouting onto a flat plate (or standard airbox). So you need the right size pod/adapter.
SR20 is different.
