Have a nearly new GT30/40 forsale
It has done all of 1500km and only been run to 1bar
I beleive it is rated at 600hp
Core number is in pictures attached
Pictures are as it came off car as you can see compressor wheel is still spotless clean
Looking for $1800
email [email protected]
https://www.sau.com.au/forums/topic/67667-gt-3040-forsale/
is this suited to the r33 gtst and what sort of lag has it got compaired to the stock one?
I couldn't tell you any answer's to the above questions as i have never had it on a r33, ..may pay to ask the question to someone in the know ,... i do beleive they do run GT30/40 on GTR's
At a guess for street use the exhaust housing would be a size to large as it is a 1.02 A/R
https://www.sau.com.au/forums/topic/67667-gt-3040-forsale/#findComment-1269340
Guys some more info on turbo as some have asked i would like to move it as I want to upgrade to a large turbo
This turbo has the GT40 compressor wheel and has a slightly smaller turbine wheel than the 700hp model
GT30
SB8006 part numer
700177-0014 corenumber
0.70 comp A/R
64 Trim
GT40 Comp Wheel
2.41/3.22 Comp Wheel size
600 HP Rating
65 Comp Flow
1.06 Turbine A/R
84 Trim
2.16/2.36 Turbine Size
this info is off Ray Halls site
https://www.sau.com.au/forums/topic/67667-gt-3040-forsale/#findComment-1289031
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
