Chris32 Posted March 18, 2005 Share Posted March 18, 2005 Anybody had any drama's with there knock sensors? on RB20's in particular One of mine seems to be playing up and reading all over the shop, so much so that I have replaced my fuel pump as I thought it was fuel pressure related I think I may have giving one a bit of a tweak ages ago while installing my oil cooler kit My tuner says that everything is way conservative and the knock sensor is reading detonation (not consitsantly either) but there are no signs of detonation, and it happlily supports a extra 6 degree's timing before tell tale puffs of unburnt fuel from the exhaust, so its a long way off detonation, AFR's are low 11's Everyhting has been checked, plugs, fuel pressure etc I also had a new exhaust made up and we think that maybe the earth for the welder may have been positioned closely to one of the sensors (we can't remember) Would this cause damage? Thanks in advance, Chris Link to comment https://www.sau.com.au/forums/topic/67674-dodgy-knock-sensor/ Share on other sites More sharing options...
yogi000 Posted March 18, 2005 Share Posted March 18, 2005 I had a problem with my knock sensors when i first got the car, it was a problem with the wiring, had a breakage in the wire cause the ecu to have abit of a fit and fart past 5000rpm. Took it to my mechanic and he rewired the knock sensors back to the ecu for me. Now i have a pfc and my knock has never gone over 35 with the base map. George Link to comment https://www.sau.com.au/forums/topic/67674-dodgy-knock-sensor/#findComment-1255715 Share on other sites More sharing options...
Chris32 Posted March 18, 2005 Author Share Posted March 18, 2005 Ok, I will get this checked. I have a spare motor to take parts of too, so might do some swapping Link to comment https://www.sau.com.au/forums/topic/67674-dodgy-knock-sensor/#findComment-1255723 Share on other sites More sharing options...
Cubes Posted March 18, 2005 Share Posted March 18, 2005 Chris, Where in the rpm does it usually show knock? Link to comment https://www.sau.com.au/forums/topic/67674-dodgy-knock-sensor/#findComment-1256386 Share on other sites More sharing options...
Chris32 Posted March 20, 2005 Author Share Posted March 20, 2005 Well its funny, as it has a quick flash up to about 70-75 at around 6000rpm from what Shaun was saying, but its definatly not detonating at all just showing up on the knock sensor :confused: Other than that is between 20-25? Also if I go over a pothole it shows knock of about 50? Something tells me the sensor may have a dodgy connection.... Will have to try the spare sensors I have, hopefully fixes it up Can running good though, 1.3bar making 197rwkw and feels very strong on the road. I think my turbo might struggle to get to 220rwkw, but its heaps of fun like it is..........I am sure the driver of the Evo4 I surprised the other day can attest to this......... Link to comment https://www.sau.com.au/forums/topic/67674-dodgy-knock-sensor/#findComment-1259166 Share on other sites More sharing options...
Cubes Posted March 20, 2005 Share Posted March 20, 2005 The pothole.. lol I'd say it was a dodgy knock sensor. You run the 2510? Shauns dyno does appear to read lower than it used to so no doubt it may have been getting close with his old software/dyno what ever it was he upgraded/changed. Link to comment https://www.sau.com.au/forums/topic/67674-dodgy-knock-sensor/#findComment-1259181 Share on other sites More sharing options...
Chris32 Posted March 20, 2005 Author Share Posted March 20, 2005 yeah, pothole is what made me think last night that it must be a knock sensor problem, as Shaun said it would take 3 more degree's timing before it would start to show signs of detonation By the looks of it, it's indeed a 2510, thought it may have been 2540/30 but it was the old tune that made it laggy, now its making boost at around 2000rpm and depending on what gear, on full boost by 3300-4000rpm so its very responsive now Link to comment https://www.sau.com.au/forums/topic/67674-dodgy-knock-sensor/#findComment-1259204 Share on other sites More sharing options...
Blade Posted March 21, 2005 Share Posted March 21, 2005 If you get a knock reading of 22 on startup in the morning is that a dodgy knock sensor? I also got readings of 122 on a cruise through kinglake in 5th gear, crusiing at around 70km/h tryin to prevent compressor surge, every time it fluttered my engine light flashed and i got a reading of around 120.. Link to comment https://www.sau.com.au/forums/topic/67674-dodgy-knock-sensor/#findComment-1259438 Share on other sites More sharing options...
