300 !!!! holly craparoonie.....
The one I've got is that 10mm heat proof foam that has a silver heat reflective layer on it.
But I'm not sure if it'll fit a Blitz SUS filter. I sort of custom made it for my HKS filter.
BTW: check out the new smilie :lol: what a dude.....
HAHAHAHAHHA
I was thinking of same thing!!
i was saying to myself " if these things can help keep heat out of my car then....[insert light bulb here]"
I also went to clark rubber and bought some heat reflective foam.
Foam on one side HEATER on the other, this stuff does not WORK!
anyone know wat im supposed to look for when i go into Clark rubber?
Donnie
What I found made a big difference was to make sure that the pod is sealed from sucking air from the engine bay. It wasn't so much as the radiant heat, but the hot air that kills performance.
So I think the foam stuff would be fine if you make sure that it's sealed correctly.
It's no use just putting a heat shield there with big gaps around it and hope that it works. I'm sure it would stop alot of radiant heat, but it'll still suck in heaps of hot air. And hot air is the killer :)
Anyway, just my 2c
J
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
