Night cruise - 8th April
DJ984
 Share
1st,i got antenna wires,but no external antenna, yeh my tape did work,copied tapes, then ate a tape so i put my old kenwood deck in n its wot krapt itself, mine also come standard with a cd plaer under the original tape deck,it worked 4 awhile b4 i started using tapes coz it still has a cd of mine that wont come out same as the kenwood...hence  kenwood 7x10's 220watts n 1000watt amp
do u still have the "jap spec" japanise writing somewhere ?? i love that shitte
  • Replies 295
Aplex...your such a whore!!! just starting whoring....you know you want to
DJ - You didn't add me to the list!!! I'll be there in a white r33 gts-t. ADD ME!!!!
Looking forward to meeting a few more SAUers
hey liz i think i saw u in north sydney a couple of weeks ago, u waved and by the time i waved back u were looking elsewhere... that u???
I have a gunmetal gray r33 s1
yep yep yep.
just cleaned my car today.. scrubbed all the black of my white rims haha now they are really white and not black on the inside of the rim haha... yeah u all know u already cleaned ur lines for the cruise, or planning too beforehand haha =) see you guys there, gona be good to meet SAUers
 Share
    • Welcome.  Glad to hear that you have gained some knowledge that has helped you. I believe the only fix for the power steer belt is an electric conversion with a Holden astra pump. If you get a chance, post pics of your car, please. 🙂
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
