Night cruise - 8th April
DJ984
 Share
Geeze I was confused by page2. At this stage i'll be leaving penno at 8pm so i'll be there when im there and if I miss you all then i'll meet at Newport... whenever I get there.
Sounds like their is a fair few cars going so I might hang back abit, they tend to get abit messy when driving.
$5 the magna is there!
  • Replies 295
i think we're givin moans buffer time to get ready n stuff...
hahahahaha.. to get ready? what to get ready? the only preperation i need is a bp for fuel :D
hey carlo! i didn't get your message!!! i pm ed you my number in case you lost it :)
hey guys,
ill be there with my black R32 GTST, i might see yous at thornleigh maccas at 8:30, if not ill meet yous at waitara at 9pm, it'l be good to catch up with some old faces :D
you betta come nick n carlo, theres plenty of time for dinner :)
Hey guys, kool kool... we ssseeemmm organised :D
Actually, we're gonna need a leader 'cause my navigator hasn't gotten back to me so i dunno if he's coming... lol! (good that, the organiser doesn't know the way LOL!!!!)
SO i'll see yaz all at Waitara at about 9pm :D
Drive safe and lets have a fun night ;)
Cheers all...
P.S. Sorry if i havn't added ya to the list, my net's been playin up :)
Ciao
Dave.
massive turnout... the twisties in the cef reminded me of touge runs in melb :P
had a fuzz mobile follow me (being the last car in the pack) so drove like a granny and took a few wrong turns... when they did a U turn, I back tracked :)
so many R32's... hehe 15 yr law at full abuse in Sydney hey? Sad that no one else was there in a ceffy... but if you squint you can sorta make mine out in those pics :P.
Oh and thanks to doughboy and the wierd bald man that kept yelling "its monkey f**ker" for waking me up after my lil nap on the side of the road on my way back :)
 Share
    • Another thought, are those actually NEO cams made for the NEO head (shim over bucket) and not the non NEO head (hydraulic lifters)?
    • This is the first time I've checked my fuel pressure and I've got no idea what the pressure was before this. So I'm not sure if this is 100% the true cause of my idling problems atm, but this high pressure is my first clue to something that is "out of spec" according to the workshop manual. Also, you can see in the video, the haltech tries to get the afr target and it does maintain it at 14.2. So I would assume the afr is fine? I have to dissagree with the cluster comment. I don't think it's a bad solder joint. There's nothing wrong with my Nismo cluster because I swapped out the cluster to my old nissan one and it does the same rpm glitchy thing. So to me, thats the signal coming from the ecu that is farked. I bet if i were to put both those clusters in a working r34 gtt, it would work as it should.    I just took this video now to show what happens to the fuel pressure when I remove the vac lines on both the FPR and damper. It remains at 50psi:   Can definitly feel theres vacuum. No aftermarket reg, just stock one. I reckon its the signal coming from the ecu. So correct me if im wrong, cas send signal to ecu to show rpm of engine (and thats what we see on the haltech software) then ecu sends out ignition and injector pulses ect ect, and then spits out a signal for the rpm gauge on the cluster? Makes me wonder if something in the injectors electrically (solenoids?) or something is causing some weird feedback to the cluster signal.  Yes! They did. And I also think they are related/connected to this idle issue.  Haha sorry about it. I just filmed it with my phone. Let me know if you want me to get something els specific on vid. Yeah it's really odd. I would like to try and diagnose the injector wiring next. Don't know if that requires an oscilloscope?
    • Hi Bud, Yeah that's the next step, going to get these checked. they were set "bang on" when it was built and its always been present. They may well be wrong though!
    • @Toff if it's a NEO and it's making the noises you're describing, it sounds like you need to work on the valve clearances and measure/replace shims as required.
    • Thread revival, apologies! I have a similar issue, strange noise that appears shortly after starting the car, fluctuates a bit with RPM... If you bring the revs up the noise sort of follows / trails behind and then settles if that makes sense? Engine was built years ago with CAMTECH 268 Cams (9mm lift i believe) and the rest of the upgrade kit with the springs and retainers. Can you upgrade the pulley itself, if the spring is too weak (same as on the VG30 Lumps) or is it pointing towards another issue?   Cheers!
