Ok, i have 2 scenarios, which one is going to cause more internal damage to a RB25DET motor;
1) A smaller turbo running very high boost but producing less power or
2) A bigger turbo running less boost but producing more power
Remember both turbo's will be tuned well.
Exactly, how much boost can these motors handle or do we base it on RWKW
  • Replies 67
G'day,
I dont think the size of the turbo is what you have too worry about in regards to the damage of the engine, of course there are limitations of boost but I would be more concerned with a good tune, fuel supply and cooling to support your chosen application. I know the standard internals can support around 250rwkw you would be pushing it going much higher.
My 2c
The Stock headgasket are at their max at around 18psi.
The stock cast piston will melt as they cannot take this sort of heat (25psi) for too long periods and you don't want to be making mistakes while tuning because at this boost level many standard things can brake, stock valve springs aren't strong enough the standard cam's don't have high enough lift to let 25psi of air out in and out of the engine.
At 25psi you will be making a fair decent amount of power, the stock con-rods also wont handel the pressure & load on boost.
The RB25 is a strong motor for what it is but once you turn the boost up things start to go wrong. :D
Robo,
A bigger turbo will cause more dammage as it can physicaly flow a greater mass of air than what a smaller sized one would, eg: If you were running 18 psi through both turbo's and you got a boost spike of 23psi the smaller turbo has more chance of running out of its efficency range their for won't make much more power but a bigger turbo will keep going.
To answer you'r question, i'd would say boost, because with out boost you don't got no power but it also comes down to tuning, alot of the time this is what kills engines.
I'm sure SK will let you know what the RB25 is capable of. :D
A smaller turbo running high boost and producing less power will be pushing fairly hot air into the motor, which makes detonation et al more likely.
I'd go for the larger turbo, less boost, more power. Part of the power gain comes from lower exhaust restriction with the bigger turbine, so don't forget that. It's probably better to push a larger volume of cooler air through the motor, ultimately more power will mean higher cylinder temps, but I'd rather be making a given figure with a bigger turbo than a small one (assuming the little one is being driven to the limit of its efficiency range).
Lag, of course, is another story :rofl:
I've been told many a time only a poor tune and heat will kill an engine. Add that to miss treatment and revs. Technically the way it was explained to me boost wont kill an engine as such, it would just blow a gasket if anything.
My situation is, i got a 2530 cheap and im running 18.4psi. Im quite impressed with the results and i wouldnt mind pushing it further as i know the HKS will push more than 18psi. Yes we are dropping down to 13.5psi above 6000rpm which tells me the turbo is ineffeicent. However i am very impressed with mid range torque this turbo is pushing and if i can get some more in it in the mid range i will try. Tuning is done on the dyno to get the A/F ratios level and of course ive always got my ear out for ping.
no fuel will kill a motor so if you lean out you will melt a piston I have seen a rb25 running a to4 with a waste gate welded in the standard manifold the car was running around 270rwkw till it melted a piston due to lack of fuel
dangerous daveo, wat do u mean by miss treatment and revs? i know here and there i do push my car to atleast 6000rpm (but never redline), because im scared of damage, now how much of this can my rb25 handle?
I mean holding it on the limiter with little to no air flow (ie cooling), it really wont like it.
your main problem is fuel.. at cameron said.. running stock internals.. shit load of boost.. you'd want to thinking in the low 11's for AFR's while on boost but from wat i've heard the stock rb25 rods are only good for up to 250rwkw.. after that it comes down to how often it gets the shit reved out of it.. chuck a set of tomei pon cams in.. you'll notice a big difference all over the rev range like you see some people doin a shitload of mods.. yet there lacking power? half the time people have just ignored cam's.. but yer best bet is ask sydneykid
Warrick
timing also doesnt help so dont go bashing that cas
its better to run as little boost as possible to make the power you want, simple
but there is so much more then this... tuning, support systems such as fuel , ecu , cooler etc make the difference in the long run
i abused the hell out of my 25, it hit limiter pretty much all the time, and its still going hard.
Rb25s also have a higher compression ratio then RB20s and RB26s, so thats another thing that may mean ultimately you wont want to be running excessive boost.
There is always talk that HKS / Trust this and that turbos love big boost? Has anyone ever actually put an RTD / temp probe in their piping to see what the compressed air temps are?
I think you will find the 2530 is flowing all it can on an RB25 at around your current boot level. The fact that it has so much low/mid stomp, i wouldnt be too worried about running 1.4bar of boost and only reving the thing to 6,500rpm.
On the street i think your more a chance of running higher boost as really how long can you keep the thing on boost and hold onto your licence. If your nailing it for 10 minutes and wide open throttle there is no way id run more then 18psi.
LOL...i suppose its a matter of are you willing to lose an engine by leaining on it:), just keep the revs as low as possible if your going to wind more boost into it
    • I know mentally you're set on the ATS clutch but honestly I'm a big fan of the Nismo Super Coppermix Twin. It's much cheaper and in some ways I think it's a better design for a street/circuit car.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
