  • Replies 67
A 2530 running 1.4 bar will be pumping the same amount of air into the engine as say a GT30 running 0.9 bar boost. So its the airflow into the engine not the boost that can kill an engine.
:confused: That doesnt sound right. More airflow means you need more fuel, so more air/fuel equals bigger bang. Now this bigger bang means more power, higher loads on rods, bearings etc etc.
With boost though, the increase in cylinder pressure to get the same amount of air into the cylinder increases the loads. Or thats at least how i understand it.
If RB25s were spinning bearings, throwing rods etc, then id say your asking too much of the engine. The fact that many kill pistons tells me you want to be mindful of A/Fs and the boost level your running to make the power you are after.
I dont own an RB25 so dont listen to me, im just dribbling:)
Exactly Roy, by far the most common engine failure I see in RB25's is pistons, and that's a tuning problem. The second is valves and guess what, that's a tuning problem as well. Bearing damage is not all that common, mostly in RB26's and that is related to oil surge more than rpm.:)
Finally,
You guys are saying that a bigger turbo is better because you'r runing less boost, as i said before if you do get a boost spike and you are really pushing you'r internals you have a greater chance that the smaller turbo will run out efficency eg not being able to produce more air their for no power. As a bigger turbo will.
Finally,
1 a properly set up car will not get boost spikes
2 id rather a spike from a big turbo - at least the air wont be 100000 degrees because the turbo will be waaaaaaaaaay out of its effiecency range
in a split second spike your gonna have a massive rise in temps?
i dont think so
']1 a properly set up car will not get boost spikes
If a properly set up car won't get boost spikes then a properly set up car should have a decent cooling system, so you won't be getting temps of 100000*
The inlet temps should not vary much from running 18psi and getting spikes to 23psi, as nis said, the only real variation you'r going to get is from the outside weather temperatures.
i know of a turbo set up that would make excellent power at 18/9 psi
at 21 plus it would literally melt engines
it popped at least 5 rb20's in the hands of 3 owners. we never got to check the exact difference in heat but they where massive. why? because it was outside its efficency range.
a cooler can only do so much , it a turbo is roasting air its roasting air.
a spike in boost is more likely to damage an engine due to afr issues rather then heat anyhow.
You said: We never goto check the inlet temps when it was breaking motor's
Then you said: Heat is less likely to dammage the motor?
Anyway its all down to tuning, You can only tune to an extent intil you'r standard internals become un-safe.
You make it you break it.
thats what im trying to say, if my turbo is still making reasonable power gains as the boost is being screwed into it and my support systems are on par , air fuel ratio is spot on, inlet and exhaust temp not excessive ,how far can i go on stock internals if the tuning and support systems are spot on??? 18 psi? 20psi? 22psi? 25psi?
In the real world it simply doesn't happen like that. If you have spent enough money on the outside of the engine (bolt ons) to make what you describe possible, then you have enough money to upgrade the internals. You will have spent something like this;
Exhaust manifold ------ $1,500
Exhaust system ------ $1,400
Hi flow cat ------ $500
Turbo ------ $3,000
POD, AAI, heat shield ------ $400
Inlet manifold ------ $1,500
Camshafts ------ $1,400
Valve springs ------ $600
Adj pulleys ------ $500
Radiator ------ $700
Oil cooler ------ $800
Clutch ------ $2,000
Power FC ------ $1,100
AFM upgrade ------ $400
Boost controller ------ $500
Intercooler ------ $1,500
Injectors ------ $700
Fuel pump ------ $400
Head work ------ $1,000
Fitting labour ------ $4,000
Tuning ------ $1,000
Gauges ------ $800
Total ------ $25,700
So after spending $26K on the engine, what's another $1400 for a set of plstons? And finding that situation, plus one where nothing has gone wrong on the development path, is very unlikely. I have certainly never seen it.
:cheers:
http://www.skylinesaustralia.com/forums/sh...201#post1261201
can you help me here? I'm asking for 250rwkw with a GT 30-40 with a .63ar exhaust housing, and an injector and fuel pump upgrade.
(and a unopened motor)
You think it will handle it with a good tune?
whats the maximum boost have you used on an internally stock engine sk?
Its not about maximum boost, each turbo is different.
If you’re running a Stock r33 High flow turbo that can push 20psi,
And you’re running a T88 that is pushing 20psi.
Which one do you think is pushing more air? A T88 at 20psi is equivalent to the high flow pushing 38 psi.
You can run as much boost as your want on a stock motor, I will only last you a few days. Until things give way, Eg Head gasket, Piston ring lands, Rods... So on...
So their is no set limit on max boost for any motor. As each setup is different. And will have different effects on the motor internally.
It’s about reliability, insuring your motor lasts you longer then 1 week, and allowing good performance from it at a safe boost level.
Which all comes back down to tunning.
i was gonna say a not much different thing.
i would very much doubt a turbo would go from fine @ 19psi, to motor killing @ 21psi without something dreadfully wrong with the tuner.
funny you say that..
all popped on the same dyno
all the same tuner
no need to name names (and please dont assume i mean bad by that)
the thing was a filthy air baker, that was the call of one of turbo techs best technicans... but im sure he has no idea, right?
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
